Working on a few projects lately where I need to work with the ClockInMInute (capital I intentional) and ClockOutMinute data in LaborDtl. There are some other posts on here with the SQL to convert datetime data to clock minutes. I thought I would share some of the C# helpers I am using.
ClockInMInute and ClockOutMinute are stored as number of minutes since 1953-10-30 00:00:00. Knowing that, we can calculate datetimes based on minutes or convert minutes into datetime.
I also added a DspClockIn string time to decimal time function - I’m sure there are many out there already.
class Tests {
static void Main()
var t = new TimeHelpers();
DateOnly TestDate = new DateOnly(2023,10,11); //date only field
Decimal TestTime = 16.45m; //decimal time for 16:27 (4:27PM)
DateTime TestDateTime = new DateTime(2023, 10, 11, 16, 27, 0);
string TestDspTime = "21:17"; // epicor display is 24h
int TestMinutes = t.ConvertToEpicorMinutesFromDecimalTime(TestDate, TestTime);
Console.WriteLine(TestMinutes.ToString()); // Epicor Minutes
Console.WriteLine(TestDateTime.ToString() + " : " + t.ConvertToEpicorMinutesFromDateTime(TestDateTime).ToString()); // Epicor Minutes
Console.WriteLine(t.ConvertEpicorMinutesToDateTime(TestMinutes).ToString("yyyy-MM-dd HH:mm")); //should equal test date and time
Console.WriteLine("Dsp Format:" + TestDspTime + " Decimal: " + t.TimeToDecimalTime(TestDspTime).ToString()); //should be decimal version of TestDspTime
Console.WriteLine("Now: " + t.EpicorMinutesNow().ToString());
Console.WriteLine("Epicor Birth: " + t.EpicorBirth);
class TimeHelpers
public int ConvertToEpicorMinutesFromDateTime(DateTime InDate)
int EpicorMinutes = 0;
DateTime EpicorBirth = new DateTime(1953, 10, 30, 0, 0, 0);
EpicorMinutes = Convert.ToInt32((InDate - EpicorBirth).TotalMinutes);
return EpicorMinutes;
public int ConvertToEpicorMinutesFromDecimalTime(DateOnly InDate, decimal Time)
DateTime Day = InDate.ToDateTime(TimeOnly.Parse("00:00:00"));
int TodayMinutes = Convert.ToInt32(Math.Floor(Time * 60));
int SpanMinutes = Convert.ToInt32((Day - EpicorBirth).TotalMinutes);
EpicorMinutes = SpanMinutes + TodayMinutes;
public DateTime ConvertEpicorMinutesToDateTime (int EpicorMinutes)
int Mins = EpicorMinutes % 1440;
int Days = Convert.ToInt32(Math.Floor( EpicorMinutes / 1440m));
DateTime date = EpicorBirth.AddDays(Days).AddMinutes(Mins);
return date;
public decimal TimeToDecimalTime(string timeString)
decimal TimeDecimal = 0m;
TimeOnly time = TimeOnly.Parse(timeString);
TimeDecimal = time.Hour + Math.Round((time.Minute / 60m), 2);
return TimeDecimal;
public int EpicorMinutesNow()
return Convert.ToInt32((DateTime.Now - EpicorBirth).TotalMinutes);
public DateTime EpicorBirth { get { return new DateTime(1953, 10, 30, 0, 0, 0); } private set { } }
PS - does anyone know the significance of 1953-10-30? I assume someone’s birthday?
