ok, got to 9.05.700C on Progress...... Installed 9.05, ran SP and patch for 700C then installed DUU and ran it  and it upgraded..
Now working on the EWA.....
----- Original Message -----
Sent: Wednesday, September 12, 2012 11:12:59 AM
Subject: [Vantage] Re: Epicor 9 Conversion Error
Â
One thing I discovered is that for EACH testing pass, the Data Upgrade utility needs to be uninstalled and reinstalled, and any surviving copies of the UOM database (named UOMDB and in a couple of places) need to be deleted. The UOM Conversion Program does not overwrite previous instances.
I put it in my checklist to remove the DUU wayyy early, and then install it again AFTER I'm ready to go with 8.03.410.
Ernie Lowell
Diba Industries
moonlighting at Labsphere
--- In vantage@yahoogroups.com , jdaniel1127@... wrote:
> I was able to use data upgrade utility to get 8.03 on progress through the 9.04 part and through  the 9.05 schema change. I start admin to do the conversion, It shows the uom conversion screen and then the screen disappears, nothing in the log -waiting on Epicor Tech....
> From: "myrmtjunk" <myrmtjunk@...>
> Sent: Monday, September 10, 2012 9:20:04 AM
> ÂÂ
> I considered doing a dump and load but was hoping to go through the process accordig to their instructions.
> What i ended up doing was starting over with the process, I am now past the point where I got the error, but.. now the UOM conversion is failing. I did end up calling Tech (arghh) and they said - "oh ya this is a known issue" known to who?? Anyway i have to wait for them to send a fix.
> --- In vantage@yahoogroups.com , "Elizabeth" <gracefulthreads@> wrote:
> > If you're on Progress, you might want to try a Dump and Load on the 8.03 database. Did you do a COS/WIP Capture before backing up the 8.03 database? Are there any open AR or AP Invoice Entry groups, or open user sessions? The Schema Change doesn't really mess with the data, it mostly changes the structure of the tables. It's the Automatic Conversions that rock your world.
> > If you're on SQL, surely someone out here in Yahoo-Land can recommend tools to see what the problem is.
> > And if all else fails, you can always call support (did I really say that?)
> > Ernie Lowell
> > Diba Industries
> > --- In vantage@yahoogroups.com , "myrmtjunk" <myrmtjunk@> wrote:
> > > The error occurs after the schema change from 804 to 904- when trying to open the admin tools. Prep for db is completed on server 1 db then backup to server 2, Run upgrade tool schema change from 803 to 904 that finishes ok. When trying to open ugrade admin is when the error occured.
> > > FYI- i have restarted the conversion from the begining and currently running the upgrade admin tools schema change. So far it hasnt given me an error. will see how this one goes.
> > > On a side note-- I have also tried converting right from 804 to 905 the schema change finishes ok but when go to open it with admin tool for 905 the window comes up that says the db is still ver 804. So I ran the schema change again and got the same message. I guess it doesn't like skipping 904.
> > > BR,
> > > KR
> > > > Austin,
> > > > We're doing the same upgrade, actually starting at 8.03.305K (Progress). Exactly when are you getting the message? What steps have you completed successfully, and what causes the error?
> > > > Are you doing this in-place on the same server, or are you moving to a new server as well?
> > > > And what version are you starting out at?
> > > > Thanks and I hope I can help,
> > > > Ernie Lowell
> > > > Diba Industries
> > > > --- In vantage@yahoogroups.com , Austin Skrepak <askrepak@> wrote:
> > > > > We are working on converting our data to 9.05. When we run the data upgrade utility, we get an error:
> > > > > "Non-recoverable database conversion failure. Your data is probably corrupt. Please contact support."
> > > > > Searching through previous messages, we found this topic:
> > > > > http://tech.groups.yahoo.com/group/vantage/message/110618
> > > > > Our network administrator tried rebuilding the indexes, but we still get the same error. Any help would be greatly appreciated!
