Yes we are on SQL 64bit 701
--- In vantage@yahoogroups.com, <vantage@yahoogroups.com> wrote:
Not sure if you are on SQL but Epicor 9.05 on SQL does not have keys.
--- In vantage@yahoogroups.com , "s1mhall" <s1mhall@...> wrote:
> Yes Trying to do this in 701 and I can't get them to work. Using the add UD as a child wizard does appear to work though.
> Cheers
> Simon Hall
> --- In vantage@yahoogroups.com , "Charles Carden" <shadowcar1449@> wrote:
> > I had foreign key views in Vantage 8.03.410 that are no longer valid when we upgraded to Epicor 9. I tried to recreate the FKV but so far I have not had any luck. The main problem seems to be in the Custom Column Like as it will not retain the Like Column Value. I have done everything I know how to do and yet I cannot get it to retain the Like Column Value. I can define it and define the FKV but when I leave the customization and exit the program The Like Column Value is missing and consequently the FKV is no longer valid.
> > Has anyone else run across this problem and if so how did you fix it?
> > Thanks in advance.
> > Charles Carden
> > IT Manager
> > Manitex, Inc.
> > Georgetown, Texas
