Good Idea, I will test. Thanks
I was really hoping Crystal could do this, I'm close in crystal, I have
tested the WhileReadingRecords, WhilePrintingRecords on RunningTotals
and got Zeros but have not used or tested the EvaluateAfter(f) and also
want to research the DO WHILE stuff in Crystal.
Patrick Winter
Of cathyattechnologicsys
Sent: Friday, July 12, 2013 17:13
Subject: [Vantage] Re: Epicor 9.05.702 - Crystal Reports - Pass a
Summary to a Group Filter?
Can you summarized the PartTran table in your BAQ?
Then you can create a Calculated field - Total(PartTran.TranQty).
"Winter, Patrick" <pjw@...> wrote:
Behalf
Patrick Winter
>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> I need the Summary of the calculated field for the job.
> Detail Lines are suppressed
> Job X100 for 4,000 MFG-STK 1,000 ------- Record Line
> Job X100 for 4,000 MFG-STK 2,000 -------- Record Line
> Job x100 for 4,000 Sum(Mfg-Stk) 3000 ------- Group 1 Footer (Filter
> = Sum(MFG-STK for 3,000) <> Job.ProdQty)
> BAQ will only filter on record level. I want to filer at the Group
> Level.
> Patrick Winter
Behalf
> Of cathyattechnologicsys<mailto:vantage%40yahoogroups.com> ,
> Sent: Friday, July 12, 2013 12:45
> In your BAQ you should be able to filter on the calculated field under
> Display > Filter Results.
> You can choose your calculated field where <> a Filter Value where you
> would choose specified table field value of JobHead.ProdQty.
> "Winter, Patrick" <pjw@> wrote:so
> > All,
> > In Report Builder (centuries ago) I would "PrePass" a summary field
> I[Non-text portions of this message have been removed]
> > could FILTER on that summary.
> > Crystal BAQ Report Example.
> > Link JobHead to PartTran.
> > Group and Sort on JobNumber
> > Sum all the Part Tran Records for "MFG-STK"
> > Group 1 - Footer Line Filter for MFG-STK Qtys that Don't equal the
> > JobHead.ProdQty.
> > Seems Simple but Crystal Group Selection Formulas Just don't seem to
> > work.
> > Sum({BAQReportResult.PartTran.TranQty}) <>
> > {BAQReportResult.JobHead.ProdQty}
> > Is there another way or am I missing something?
> > All suggestions, comments welcome.
> > Patrick Winter
