Epicor 9.05.702 - Application Error - "failed to invoke method"
Is your BAQ shared?
Jim Kinneman
Encompass Solutions, Inc
I have created a context menu item on the JobNum to open a dashboard to display labor tickets.
When this particular user tries to right click on a job number and open the dashboard the get:
Application Error:
"The process caller failed to invoke method LaunchForm in Epicor.Mfg.UI.App.Launch in Epicor Mft.UI.App.JM706.dll"
I can login on the same client using the administrator account perform the task and not get the error.
JM706 is the name of my dashboard.
Any comments or suggestions appreciated.
Patrick
This e-mail and any attachments may contain confidential and privileged information. If you are not the intended and/or named recipient or recipients, please notify the sender immediately by return e-mail, delete this e-mail and destroy any copies. Any dissemination or use of this information by a person other than the intended recipient or recipients is unauthorized and may be illegal. Any views or opinions expressed in this email are those of the author and do not necessarily represent those of the Specialty Screw Corporation. Warning: Although precautions have been taken to make sure no viruses are present in this email, Specialty Screw Corporation cannot accept responsibility for any loss or damage that may arise from the use of this email or attachments.
This e-mail and any attachments may contain confidential and privileged information. If you are not the intended and/or named recipient or recipients, please notify the sender immediately by return e-mail, delete this e-mail and destroy any copies. Any dissemination or use of this information by a person other than the intended recipient or recipients is unauthorized and may be illegal. Any views or opinions expressed in this email are those of the author and do not necessarily represent those of the Specialty Screw Corporation. Warning: Although precautions have been taken to make sure no viruses are present in this email, Specialty Screw Corporation cannot accept responsibility for any loss or damage that may arise from the use of this email or attachments.   ­­
