Epicor 10 BAQ SSRS Help
 As you know, when creating a BAQ Crystal Report in the BAQ Report Designer for E10 you give it a ReportID, select the BAQ, click save, and when you do the BAQ Report Designer creates the .rpt and throws it in the Custom Reports folder.  What it also should do, is create an .rdl (the SSRS Report) and throw that in the appropriate SSRS server folder. What we found was that the BAQ Report Designer was throwing the .rdl in the wrong folder.  We tried to move it to the appropriate folder, but failed repeatedly.  I thought I remember reading some where there is a hotfix/scr for this issue, does anyone have this info?
Thank you,
B-
