Enterprise Search version mismatch
Does anyone know where the Enterprise Search client version is read from?
My ES DB was 68GB, so Epicor recommended uninstalling ES and admin console and starting over to see why the DB was so large. I have uninstalled and re-installed them several times and I get a version mismatch 700C ( client )  to 702A (server ) when trying to create the index. I have checked the client and all of the mfgsys files, mfgsys.ver and none that I can find have 700C in them.
ES is running on my SQL server and I have looked everywhere I can think of on the app server and sql server.
I will get back with Epicor on Tuesday, but was hoping to have fixed before then.
Greg Payne
Message when trying to create index.
System.ServiceModel.FaultException`1[System.ServiceModel.ExceptionDetail]: Version mismatch between client (9.05.700C) and server (9.05.702A). (Fault Detail is equal to An ExceptionDetail, likely created by IncludeExceptionDetailInFaults=true, whose value is:
Epicor.Search.Exceptions.EpicorSearchException: Unable to retrieve company list. Reason: Version mismatch between client (9.05.700C) and server (9.05.702A). ----> Epicor.Mfg.Common.BusinessObjectException: Version mismatch between client (9.05.700C) and server (9.05.702A). ----> Progress.Open4GL.Exceptions.RunTime4GLErrorException: ERROR condition: The Server application has returned an error. (7243)  (7211)
   at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID, String procedureName, ParameterSet parms, Boolean persistent, Boolean internal_Renamed, Int64 procId, MetaSchema localSchema, Int32 stateModel)    at Progress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String requestID, String procedureName, ParameterSet parms, MetaSchema schema)    at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String procedureName, ParameterSet parms, MetaSchema schema)    at Epicor.Mfg.Core.CallCont...).
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
