Ensure IIS User has File Access
Ok - I must be missing something, but a new deployment on a test server of 10.1.500.14 fails consistently at the same point: “Ensure IIS User has File Access”
I have adjusted every account/permission I can think of, including some that shouldn’t be to try and get past this. A recent deployment using identical setting worked like a champ…
Here is the error
Application Server Setup Failed.
Errors:
System.UnauthorizedAccessException: Attempted to perform an unauthorized operation.
at System.Security.AccessControl.Win32.SetSecurityInfo(ResourceType type, String name, SafeHandle handle, SecurityInfos securityInformation, SecurityIdentifier owner, SecurityIdentifier group, GenericAcl sacl, GenericAcl dacl)
at System.Security.AccessControl.NativeObjectSecurity.Persist(String name, SafeHandle handle, AccessControlSections includeSections, Object exceptionContext)
Did you share the epicordata folder on this new server. If not, share it and try again
Yes - reaffirmed all of the Shares are setup properly. Ports are all open on the firewall. I am going to review AV exclusions with the IT Managed Service Provider. That’s all I can imagine might be the issue at this point
AV exclusions have all been applied and the issue continues with the exact same error.
At this point probably just need to blow away the VM and start over.
I’ve come across it before on Windows 2012 R2… But on Windows 2016 it all worked fine. I had to follow the following:
Unsure as to why… sometimes IIS grants IIS_ISURS permissions and sometimes it doesn’t.
Thank you - turns out the problem is some how related to having an APPSERVER defined with the full servername.doaminname.com versus just server name
Example: If server name equals epicor1 and the Appserver node in the admin console is defined as epicor1.domainname.com then the deployment of a new instance fails every single time.
If I define it as just epicor1, and with EVERYTHING else identical…it works perfectly deploying a new instance.
This is likely a customer specific issue, but I stumbled across this little workaround out of sheer frustration. “It can’t hurt to try one more thing.” Dropping the .domainname.com solved it.
