We are trying to keep concurrent in-force Revs on a part, (you can use part rev a or b to make the part)
In creating a higher level Parent Part BOM, we want to choose and use a particular Rev of the Raw Material Part and have the appropriate method displayed with the “view as assembly” switch “on”.
Epicor E10 does not seem to have that capability: any other opinions or suggestions of how to get that functionality using Epicor?
I know that you can do what you’re asking for in a job. If there are multiple approved revisions for a part, you can choose which one to use (including child parts). Then doing “get details” for the part will pull the MOM for the revision you selected.
I agree but that logic works when building a Parent Part Method.
If you pull a subassembly into a Parent Part, even though the sub assembly has multiple approved revisions, only the latest dated Rev is automatically chosen.
At the lower level assembly, there is no option to choose from in-force revs.
