Engineering Workbench Approvals
Thanks! That is exactly what I needed to do~!
--- In vantage@yahoogroups.com, "vantage" <vantage@...> wrote:
> Go to the list tab and select the part. Then select the detail tab
and you
> should see the approval on the right side of screen. Then actions >
revision
> > check in.
> Steve
> -----Original Message-----
> From: vandertop26 [mailto:josh_vtop@...]
> Sent: November 14, 2008 3:50 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Engineering Workbench Approvals
> Upgraded to Vantage 8.03.406 and we seemed to have lost the ability to
> approve a single checked out part number from the engineering
> workbench. The only approval option is under the group and it
> approves all the the part numbers checked out under that ECO.
> Anyone else seen this and figured out another way to get a single
> approval (when multiples are checked out)?
> Thanks!
Thanks!
Go to the list tab and select the part. Then select the detail tab and you
should see the approval on the right side of screen. Then actions > revision
> check in.
Steve
Thanks!
