Engineering Work Bench
For reference, we're on 5.20. HTH.
Sent: Wednesday, 10 December 2003 7:15 AM
Subject: [Vantage] Engineering Work Bench
In the EWB (Engineering Work Bench):
Part Rev Lookup - Type Filer = Checked Out Only or All.
What does All actually display?[Gil Amilbangsa] Lists all manufactured parts in the part master. If you try to chose one that is not checked out to the current group, will tell you so.
What does "Validate Bills" actually do?[Gil Amilbangsa] Checks for cyclical reference, a part being a component of itself.
What does "UNDO CHECKOUT" actually do?
Is undo all changes but leave the part unapproved a good answer?[Gil Amilbangsa] Checks the revision back in as is nothing has happened. This reverses all the changes you have made to a revision in the workbench. If the revision was approved when checked out to the workbench, it should remain approved when returned to the active Part Master by the undo command.Remember that subassemblies are treated separately from the parent part, i.e. you need to check them out and check them in separately from the parent part.
Patrick Winter
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cujbm1r/M=267637.4116732.5333197.1261774/D=egroupweb/S=1705007183:HM/EXP=1071090897/A=1853618/R=0/*http://www.netflix.com/Default?mqso=60178338&partid=4116732> click here
<http://us.adserver.yahoo.com/l?M=267637.4116732.5333197.1261774/D=egroupmail/S=:HM/A=1853618/rand=928734906>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Patrick Winter
We are new to Engineering Work Bench V6.0.
Does each person have to have their own group?
Can document associations be done outside of the workbench?
Is ECOREV the best table to use for info about Groups,Parts,Revs etc.?
We have been using ECOREV as displayed through a report builder print
preview
To track activity in the Engineering Work Bench.
Thanks for your help,
John Mansfield
General Sheet Metal
Sent: Tuesday, December 09, 2003 4:15 PM
Patrick Winter
ADVERTISEMENT
roupweb/S=1705007183:HM/EXP=1071090897/A=1853618/R=0/*http:/www.netflix.
<http://docs.yahoo.com/info/terms/> Terms of Service.
How do you remove/delete a group from the Engineering Work Bench?
John Mansfield
General Sheet Metal
Patrick Winter
ADVERTISEMENT
From Engineering workbench screen, browse Group > Update > Tick Close.
Should disapper from browse Group until you choose All Group radio button.
HTH,
Gil
Sent: Wednesday, 10 December 2003 7:26 AM
Subject: RE: [Vantage] Engineering Work Bench
John Mansfield
General Sheet Metal
Patrick Winter
ADVERTISEMENT
< http://rd.yahoo.com/SIG=12cujbm1r/M=267637.4116732.5333197.1261774/D=eg
< http://us.adserver.yahoo.com/l?M=267637.4116732.5333197.1261774/D=egrou
< http://groups.yahoo.com/group/vantage/files/>
< http://docs.yahoo.com/info/terms/> Terms of Service.
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cfviq07/M=267637.4116730.5333196.1261774/D=egroupweb/S=1705007183:HM/EXP=1071091588/A=1853618/R=0/*http://www.netflix.com/Default?mqso=60178338&partid=4116730> click here
<http://us.adserver.yahoo.com/l?M=267637.4116730.5333196.1261774/D=egroupmail/S=:HM/A=1853618/rand=720621674>
