I just assumed that when someone wants to see when their employees
clocked in, they want to see when they really clocked in. But then,
I'm not a finance guy. :)
To relate to the empbasic table, you can edit the query generated by
the query builder and add the following after the for each loop on
laborhed, just in front of the colon. Note the comma at the
beginning:
, each empbasic no-lock where empbasic.company = laborhed.company and
empbasic.empid = laborhed.employeenum
--- In vantage@yahoogroups.com, "saab_barracuda" <chris.clunn@...>
beginning:
wrote:
>table
> Tom,
> The adjusted time is the "official" time for payroll and job costing
> so I would use laborhed.dspclockintime and laborhed.dspclockouttime
> rather than the actuals. The adjusted time takes into account the
> grace period (if setup in Company) instead of the actual minute the
> employee clocked in. We also have a policy if any changes are to be
> made, they are made to the adjusted rather than actual. The dsp
> prefix is for the display time in conventional HH:MM format ratherthird
> than decimal time (if setup). Also, I would strongly recommend the
> use of payrolldate rather than clockindate. Payrolldate handles
> shift better, shows when people forget to clock out, etc. The stockif
> labor edit report is based on clock-in date and is complete garbage
> you run 3 shifts around the clock or want to troubleshoot laborentry
> errors.to
> I'm a not very good with the 6.1 BAQ but I couldn't get the query
> wizard to relate the laborhed and empbasic tables. You might need
> do a report builder or ODBC report.Query
> Good luck.
> Chris
> --- In vantage@yahoogroups.com, "markewhittaker" <markewhittaker@>
> wrote:
> > That's all in the laborhed and empbasic tables. Fields are:
> > laborhed.actualclockindate, laborhed.employeenum, empbasic.name,
> > laborhed.actualclockintime, laborhed.actualclockouttime
> > Is that what you needed to know?
> > Mark
> > --- In vantage@yahoogroups.com, "sh4m4n71x" <lunar@> wrote:
> > > Is it possible to create a csv report in Business Activity
> > that
> > > would show employee clock in time for particular day and shift?
> > > I'd appreciate if anyone could point me in the right direction.
> > > Something like this would be nice:
> > > Date, Clock Number, Name, Clock in time, Clock out time.
> > > Thanks,
> > > Tom.
