Hi,
We have migrated in 10.2.300 and I’m facing a problem. The refresh in a dashboard added through a panel in a customization is not working.
Specs: Assembly Dashboard with it’s own display bar.
So, I did a test. I’ve created a simple BAQ, create an Assembly Dashboard with it. No tracker. Build it. Added it to the menu. So far so good, it’s working.
Then, I added the dashboard in a customization (AppBuilder Panel), select the AppControl Menu ID, Check the Display Dashboard Tool Bar, select Neither Subscribe nor Publish. Close the customization, clear client cache, Close Epicor. Reopen Epicor.
Reopen the Form and the dashboard is not executing the BAQ.
Do I miss something?
Regards,
