I have used RightFax to to generate past due invoices and past due
suppliers for another product. Basically, you embed codes, such as
<phone: 312-555-1212> using a certain font (can't recall which ones
off hand) and the fax server strips it off and sends your fax. The
only catch is you have to generate a separate print job for each (20
invoices = 20 print jobs). I don't see this as a big deal, other
than you need to create a loop, and can't just send off one big
report. I believe you can also do the same with ZetaFax, which is a
lower cost product. The only thing you would need to check on is if
you can control the font in Crystal (I haven't done much with Crystal
and fonts) because the fax server can only decode certain ones. It
works REAL slick, and should work with just about any document you
can print, control the font, and can embed codes in. The last time I
checked, both companies had evals you could download and try for 30
days. Since you are a Vantage user, you probably already know
Crystal, so that just leaves installing the fax software. In short,
shouldn't be much of a learning curve at all for a Vantage customer.
Tip: You will also need to set up a special RightFax Queue, otherwise
you'll get prompted with a print dialog box each time. Rightfax has
docs on this. Again, not much effort required -- after you do it
once, it is as quick as adding a network printer.
--- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@y...>
wrote:
>had any
> > This is probably a long shot but wondering if anyone out there
> > experience in somehow atomically emailing or faxing invoices fromVantage
> > either with some type of add on software...output
> I have used eFORMz by Minisoft. You send your character-based print
> to a folder and it merges it with a form and then can print, email,and/or
> fax. Forms are created in any Windows program. It creates PDFattachments
> for emailing and can group multiple documents to a single receiver.clients use
> http://www.minisoft.com/pages/business/eformz/eformz.htm
> I don't have any relationship with these guys but a couple of my
> this product.
> Mark W.
