Email not working
Not sure if it matters, but all the examples I've seen/used had the line
run Bpm/BpmEmail.p persistent set hEmailEx.
following define variable statements before the query.
--- In vantage@yahoogroups.com, "adrian.lauchlan" <adrianlauchlan@...> wrote:
> I can't get the email from the code below to send - the msg is displayed ok though. I can't see where it is going wrong - anyone able to tell me?
> Define Variable vFrom as Character No-Undo initial '':U.
> Define Variable vTo as Character No-Undo initial '':U.
> Define Variable vCC as Character No-Undo initial '':U.
> Define Variable vBCC as Character No-Undo initial '':U.
> Define Variable vSubject as Character No-Undo initial '':U.
> Define Variable vBody as Character No-Undo initial '':U.
> Define Variable hEmailEx as Handle no-undo.
> FIND FIRST ttRcvDtl WHERE ttRcvDtl.Company = CUR-COMP AND ttRcvDtl.rowmod <> " " NO-LOCK NO-ERROR.
> IF AVAILABLE ttRcvDtl THEN
> FIND FIRST part WHERE ttRcvDtl.partnum = part.partnum NO-LOCK NO-ERROR.
> IF AVAILABLE part THEN
> DO:
> if part.checkbox19 = true then
> DO:
> ttRcvDtl.BinNum = 'INSP'.
> {lib/PublishEx.i
> &ExMethod = 'UpdateBefore'
> &ExTable = 'RcvDtl'
> &ExField = ''
> &ExMsg = "String(Part.PartNum) + ' Requires Inspection - Please inform the Inspection Team'"}
> {&THROW_Private}.
> assign vFrom = vFrom + 'EpicorAdmin@<company>.com'.
> assign vTo = vTo + 'adrian@<company>.com'.
> assign vCC = vCC + 'adrianlauchlan@...'.
> assign vBCC = vBCC + 'adrian@...'.
> assign vSubject = vSubject + 'Inspection Required'.
> assign vBody = vBody + 'Inspection Required : PO Number: ' + String(ttRcvDtl.PONum) + ' Part: ' + String(ttRcvDtl.partnum) + ' Qty: ' + String(ttRcvDtl.VendorQty).
> run SendEmail in hEmailEx(false,CUR-COMP,vFrom,vTo,vCC,vBCC,vSubject,vBody,"":U).
> if valid-handle(hEmailEx) then delete procedure hEmailEx.
> /* {lib/PublishInfoMsg.i
> &InfoMsg = "'Inspection Required : PO Number: ' + String(ttRcvDtl.PONum) + ' Part: ' + String(ttRcvDtl.partnum) + ' Qty: ' + String(ttRcvDtl.VendorQty)"} */
> end.
> END.
DO:
DO:
{lib/PublishEx.i
&ExTable = 'RcvDtl'
&ExField = ''
{&THROW_Private}.
end.
END.
