I just made a font change to a field and I got the following error.
I even had backup from before the change and it kept giving me the error
Program Ice.Services.Lib.RunTask when executing task 525270 raised an unexpected exception with the following message: RunTask:
Ice.Core.SsrsReporting.SsrsCaller.SsrsException: The SSRS server returned the status code 500 (InternalServerError) with the following error text:
The operation you are attempting on item 'Folder' is not allowed for this item type. ---> Microsoft.ReportingServices.Diagnostics.Utilities.WrongItemTypeException: The operation you are attempting on item 'Folder' is not allowed for this item type.
at Ice.Core.SsrsReporting.SsrsCaller.SoapCaller.Call[TContent,TResponse,TSoapHeader](String actionName, TContent content, TSoapHeader soapHeader) in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsCaller\SoapCaller.cs:line 47
at Ice.Core.SsrsReporting.SsrsCaller.ReportingService.GetItemDefinition(String itemPath) in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsCaller\ReportingService.cs:line 70
at Ice.Lib.ICECommon.ReportStoreHelper.GetReportHash(String[] filePaths, Func2 fileContentReader) in C:\_releases\ICE\ICE4.3.100.8\Source\Shared\Lib\Ice.Lib.ICECommon.Shared\ReportStoreHelper.cs:line 30
at Ice.Core.SsrsReporting.ReportProcessorBase.IsLatestVersionDeployed(IReportingService reportingService, String itemPath, String contentHashForLatestVersion) in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 405
at Ice.Core.SsrsReporting.ReportProcessorBase.DeployReportIfNeeded(String printProgram, String fullReportPath, SsrsConfigurationInformation configurationInfo, Func1 reportingServiceCreator) in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 468
at Ice.Core.SsrsReporting.ReportProcessorBase.RenderReport_HttpClient(String ssrsRenderFormat, String printProgram, Boolean ignorePageSettings) in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 375
at Ice.Core.SsrsReporting.ReportProcessorBase.RenderReport(String ssrsRenderFormat, String printProgram, Boolean ignorePageSettings) in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 280
at Ice.Core.SsrsReporting.ReportProcessorBase.RenderReportForPreviewOrGenerate(RenderedSsrsReport renderedReport) in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 643
at Ice.Core.SsrsReporting.ReportProcessorBase.ProcessReportPart(String reportLocation) in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 168
at Ice.Core.SsrsReporting.StandardReportProcessor.ProcessReportParts() in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\SsrsReporting\StandardReportProcessor.cs:line 31
at Ice.Core.SsrsReporting.ReportProcessorBase.ProcessReport(ReportDatabaseBuilder reportDatabaseBuilder, ReportInstanceInformation reportInstanceInformation) in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 97
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.<>c__DisplayClass18_0.<RenderUnroutedSsrsReport>b__0(ReportInstanceInformation instance) in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 362
at Ice.Core.RoutingAndBreaking.ReportPersister.Persist(ReportInstanceInformation reportInstance, Func2 reportsRenderer, Action1 fillSysRptLstRow, Action2 processReport, Func3 filterTableAttachmentsFunc) in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ReportPersister.cs:line 58
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RenderUnroutedSsrsReport() in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 360
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RunSsrsReportIfEnabled() in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 243
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.ProcessUnroutedReport() in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 236
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.ProcessReportWithDataInPlace(Func2 executeCommand, Func2 executeReader, SqlObjectsCreated sqlObjectsCreated) in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 121
at Ice.Core.RptBase.ReportDatabaseBuilder.ProcessReportWithDataInPlace(SqlConnection connection) in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 135
at Ice.Core.RptBase.ReportDatabaseBuilder.XMLClose() in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 96
at Ice.Core.RptTaskBase1.XMLClose() in F:\_Releases\11.3.100\UD11.3.100.8\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 230
at Ice.Internal.XA.DataBuilders.DatabaseReportDataBuilder.RunReport(ReportDatabaseConnectionHelper reportDatabaseConnectionHelper) in C:\_releases\ICE\ICE4.3.100.0\Source\Server\Internal\XA\XABaqRpt\DataBuilders\DatabaseReportDataBuilder.cs:line 94
at Ice.Internal.XA.DataBuilders.DatabaseReportDataBuilder.RunReportWithErrorHandling(ReportDatabaseConnectionHelper reportDatabaseConnectionHelper) in C:\_releases\ICE\ICE4.3.100.0\Source\Server\Internal\XA\XABaqRpt\DataBuilders\DatabaseReportDataBuilder.cs:line 56
at Ice.Internal.XA.DataBuilders.DatabaseReportDataBuilder.WriteData() in C:\_releases\ICE\ICE4.3.100.0\Source\Server\Internal\XA\XABaqRpt\DataBuilders\DatabaseReportDataBuilder.cs:line 44
at Ice.Internal.XA.BAQReport.DetermineOutputLocationAndWriteTables(String outputFileName, DataSet baqResultData) in C:\_releases\ICE\ICE4.3.100.0\Source\Server\Internal\XA\XABaqRpt\BAQReport.cs:line 102
at Ice.Internal.XA.BAQReport.WriteTables(String outputFileName, DataSet baqResultData) in C:\_releases\ICE\ICE4.3.100.0\Source\Server\Internal\XA\XABaqRpt\BAQReport.cs:line 95
at Ice.Internal.XA.BAQReport.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:\_releases\ICE\ICE4.3.100.0\Source\Server\Internal\XA\XABaqRpt\BAQReport.cs:line 44
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:\_releases\ICE\ICE4.3.100.8\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 70
at Ice.Hosting.TaskCaller.ExecuteTask() in C:\_releases\ICE\ICE4.3.100.8\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 61
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:\_releases\ICE\ICE4.3.100.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 57
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:\_releases\ICE\ICE4.3.100.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 457
