Edit Quick Search
I have just copied the first quick search and baq for the sales order I haven't found any other way
Sent from my Verizon Wireless BlackBerry
Date: Wed, 19 Aug 2009 08:03:51
To: <vantage@yahoogroups.com>
Subject: Re: [Vantage] Re: Edit Quick Search
I have created a quick search for the Quote Entry screen where it displays only sellable parts as well.
I have created another for the Sales Order Entry screen where it displays only sellable parts too.
They both use the same BAQ, but if I set one as the base default and context default when called from the Quote Entry screen, it won't let me use the 2nd quick search as the Base Default and Context Default from the SO Entry screen when it is called from the SO Entry screen.
I dont want to / cant set it as All Occurances because I dont want this search on screens such as PO Entry, Job Entry etc.
Any ideas how I do it?
Sent: Wednesday, 19 August, 2009 0:37:19
If you create a quick search and click on all occurences. Then wherever there is a custid field your quick search will be available as in the cust tracker
Date: Tue, 18 Aug 2009 22:14:29
To: <vantage@yahoogroups .com>
Subject: [Vantage] Re: Edit Quick Search
Karens suggestion is actually how I stumbled across it. I ended up changing the BAQ that it was using and editing the criteria for the quick search.
It was already in the system, I assume as a default since its a new installation and no one else working on the system has made any to my knowledge.
Although I now know how to craete new quick searches, I still have to figure out how to make them show up on the customer tracker, customer search, but that's unnecessary for now since the cust search works the way I want.
Thanks again everyone!
Aaron
--- In vantage@yahoogroups .com, advantage@.. . wrote:
> First of all your userid must have can maintain quick search priveleges then as Karen says you can right click on that cust ID field and pick Quick Search entry. That quick search you said was already created? By whom? If so you can search for that quick search and see what baq it is using anD edit it to include customer name or start another one
> Also for more info the Epicor User's guide is very good and search for how to docs on Epic web
> From: "Karen Schoenung" <kschoenung@ ...>
> Date: Tue, 18 Aug 2009 16:41:58
> Subject: RE: [Vantage] Re: Edit Quick Search
> You can right click on a field and one of the options is "quick search
> entry"...Then, it brings up the screen to create one...if you type in a
> name for your quick search entry that does not already exist, it will
> ask to add new? There is a button for BAQ on this screen after you name
> it...then look at the options under NEW to see how to add a prompt etc
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
> Of tomrippity02
> Sent: Tuesday, August 18, 2009 4:27 PM
> To: vantage@yahoogroups .com
> So the Customer Tracker uses a Quick Search zCustByContact. I have no
> idea how to create a new quick search, nor associate that quick search
> with my customer search screen.
> Thanks for the prompt response!
> Aaron
> --- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ,
> "Karen Schoenung" <kschoenung@ > wrote:
> > Just from memory, each quick search you create, you can create a
> prompt
> > and return value? So, you need a new one that prompts for Company Name
> > and returns Customer Number? based on company name...I think you also
> > need this as a field (customer name) in a BAQ that your quick search
> > uses...
> > From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> [mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
> Behalf
> > Of tomrippity02
> > Sent: Tuesday, August 18, 2009 4:01 PM
> > To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> > Subject: [Vantage] Edit Quick Search
> > I am trying to edit the customer search screen to allow me to search
> by
> > customer name. Currently we can do a quick search and look by contact
> > first, last names and phone or email, but not by the company name.
> > Can someone please tell me where I can look to find instruction, or
> just
> > point me in the right direction?
> > Thanks!,
> > Aaron
I am trying to edit the customer search screen to allow me to search by customer name. Currently we can do a quick search and look by contact first, last names and phone or email, but not by the company name.
Can someone please tell me where I can look to find instruction, or just point me in the right direction?
Thanks!,
Aaron
Just from memory, each quick search you create, you can create a prompt
uses...
Of tomrippity02
Thanks!,
Aaron
So the Customer Tracker uses a Quick Search zCustByContact. I have no idea how to create a new quick search, nor associate that quick search with my customer search screen.
Aaron
> uses...
> Of tomrippity02
> Thanks!,
> Aaron
> Aaron
> > uses...
> > Of tomrippity02
> > Thanks!,
> > Aaron
Actually, I may have solved my problem by pilfering around!
Of tomrippity02
Aaron
prompt
> uses...
Behalf
> Of tomrippity02
by
just
> Thanks!,
> Aaron
Of tomrippity02
Aaron
prompt
> uses...
Behalf
> Of tomrippity02
by
just
> Thanks!,
> Aaron
Aaron
> From: "Karen Schoenung" <kschoenung@...>
> Of tomrippity02
> Aaron
> prompt
> > uses...
> Behalf
> > Of tomrippity02
> by
> just
> > Thanks!,
> > Aaron
Aaron
> Of tomrippity02
> Aaron
> prompt
> > uses...
> Behalf
> > Of tomrippity02
> by
> just
> > Thanks!,
> > Aaron
Â
Aaron
> Of tomrippity02
> Aaron
> prompt
> > uses...
> Behalf
> > Of tomrippity02
> by
> just
> > Thanks!,
> > Aaron
