Hi,
Over the weekend something happened and we cannot get our EDI Import process to recognize the current EDI import folder. The folder lives on a different server other than our Epicor 9 server. We can transfer the import files to a folder on our Epicor 9 server and then the import works. Not sure what could have happened. Any suggestions?
This is the error we get:
Exception caught in: Epicor.Mfg.Proc.ImportEDI
Error Detail
Message: Invalid Import Folder.
Type: Error
Program: Proc/ImportEDI/ImportEDI.p
Method: verifyOutputLocation
Table: ImportEDI
Row:
Field: InboundPath
Stack Trace
at Epicor.Mfg.Proxy.ImportEDIImpl.SubmitToAgent(ImportEDIDataSet ds, String agentID, Int32 agentSchedNum, Int32 agentTaskNum, String maintProgram)
at Epicor.Mfg.UI.Adapters.ImportEDIAdapter.SubmitToAgent(String agentID, Int32 agentSchedNum, Int32 agentTaskNum)
at Epicor.Mfg.UI.Proc.ImportEDI.Transaction.adapterSubmitToAgent(String agentID, Int32 angetSchedNum, Int32 agentTaskNum)
at Epicor.Mfg.UI.FrameWork.EpiProcedureTrans.SubmitToAgent(String agentID, Int32 angetSchedNum, Int32 agentTaskNum)
Inner Exception
ERROR condition: The Server application has returned an error. (7243) (7211)
Inner Stack Trace
at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID, String procedureName, ParameterSet parms, Boolean persistent, Boolean internal_Renamed, Int64 procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure(String requestID, String fullProcedureName, ParameterSet inparams, Object procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String requestID, String procedureName, ParameterSet parms, MetaSchema schema)
at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String procedureName, ParameterSet parms, MetaSchema schema)
at Epicor.Mfg.Core.CallContext.CallContextPersistentProc.runProcedure(String procedureName, ParameterSet parameters, MetaSchema metaSchema)
at Epicor.Mfg.Core.CallContext.ProxyHelper.CallMethod(String methodName, ParameterSet parameters, MetaSchema metaSchema, BLConnectionPool connPool, Session connection, PersistentProc persistProc, CallContextDataSet callContextDataSet)
Thanks!
Jill Schoedel
