Hi,
i have a BPM in DemandEntry.ProcessingDemand. It works correctly when a user goes in Demand Entry>Actions>process Demand. We use have 850 (Pos) accept manually so the BPM worked correctly.
We recently changed to Accept if no errors but the BPM is not triggering. i have run a trace but can’t see what methods are being called when a Po gets processed automatically without the user going into demand entry. I am looking for the method so i can add the logic from the BPM to work on the automatic processing of the PO.
Thanks Arul. I did what you suggested but it’s not firing the email notification. My Condition is "The ttOrderHed.EDIOrder field for the added row is equal to the true expression. This is on the Standard Data Directive. Am I missing something? Thanks
