I have setup Data Discovery, finally!, and now when I log into Epicor (we have SSO), it asks me for a Username and Password. This only happened AFTER EDD was installed. So, why is it asking me for user credentials?
turn the SSL to ignore on the Site IIS and restart
Will credentials be sent in the clear then? Never messed with that flag.
Epicor doesn’t use the ssl in IIS. Its encrypted from Epicor to the AD server
Regards,
Chris Wineinger
I was under the influence that REST uses IIS SSL and that EDD uses REST. No?
No. We are using Rest Services with our ECC Store and its not turned on in IIS.
SSL is turned off of the Epicor App Server that provides the REST services?
Using Azure AD to connect the ECC store to Epicor REST services?
