EDD Configuration after server domain change
I changed the domain of the test servers where ERP10.2.400 was installed. I redeployed the installation of the development environment through the Admin Console and got the Epicor to run under the new domain.
The problem is that EDD still points to the old server name after redeploy.
I modified the following configuration files manually with no luck:
wwwroot\edd\Epicor.Bi.DataDiscovery.REST\web.config
www root\edd\UI\sysconfig.json
when I look at the EDD configuration in the application server configuration, the extension shows as deployed on the right server with the WRONG extension url pointing to the old server (app.olddomain.local/edd/index.html)
I can login directly in edd from the server itself but not remotely (the login screen shows the login with… with no prompt)
As for Epicor itself, it says that Data Discovery is not currently online.
We did not make customizations to EDD, so I don’t mind uninstalling and reinstalling it. Just not sure what is the best solution at this stage.
HI, I’m also getting same in server it is working . But in local system not working.
Anyone, Any idea about this
