I am trying to add Materials to a Part in EWB. I have all the code working except for the materials.
FYI, I was able to get around this using UpdateExt, but it seems REALLY slow…
Here is my code:
foreach (Newtonsoft.Json.Linq.JObject mtl in jObj["EcoMtls"])
hEWB.GetNewECOMtl(ref dsEWB, groupID, partNum, defaultRev, "");
Erp.Tablesets.ECOMtlRow mtlRow = dsEWB.ECOMtl.First(M => M.Added());
mtlRow.MtlPartNum = (string)mtl["MtlPartNum"];
hEWB.ChangeECOMtlMtlPartNum(ref dsEWB);
hEWB.ChangeECOMtlRelatedOperation(relatedOp, ref dsEWB);
mtlRow.QtyPer = (decimal)mtl["QtyPer"];
hEWB.ChangeECOMtlQtyPer(ref dsEWB);
hEWB.Update(ref dsEWB);
The error I get is:
System.NullReferenceException: Object reference not set to an instance of an object.
at Epicor.Data.DBExpressionCompiler.GetObjectSetCache[TResult](EpiDataContext dataContext, Cache cacheSetting) in C:\_releases\ICE\ICE3.2.700.28\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 354
at Epicor.Data.DBExpressionCompiler.InvokeSingle[TDataContext,TQuery,TResult](Expression expression, Cache currentCacheSetting, Boolean cacheQuery, TDataContext dataContext, Func`2 getDataCacheKey, Func`2 compileQuery, Func`3 executeQuery) in C:\_releases\ICE\ICE3.2.700.28\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 256
at Epicor.Data.DBExpressionCompiler.<>c__DisplayClass58_0`6.<Compile>b__0(TContext context, TArg1 arg1, TArg2 arg2, TArg3 arg3, TArg4 arg4) in C:\_releases\ICE\ICE3.2.700.28\Source\Framework\Epicor.System\Data\DBExpressionCompiler.Generated.cs:line 1169
at Erp.Internal.BM.BMM10_GD.IsEcoRevCheckedOut(String company, String partNum, String revisionNum, String altMethod) in C:\_releases\ERP\ERP10.2.700.28\Source\Server\Internal\BM\EngWBLib\BMM10-GD.i.Queries.cs:line 1522
at Erp.Internal.BM.BMM10_GD.FindEndlessLoop(String partNum, String revisionNum, String altMethod, Boolean isECOMtl) in C:\_releases\ERP\ERP10.2.700.28\Source\Server\Internal\BM\EngWBLib\BMM10-GD.i.cs:line 1047
at Erp.Internal.BM.BMM10_GD.CrcCheck(String partNum, String revisionNum, String altMethod, Boolean isECOMtl) in C:\_releases\ERP\ERP10.2.700.28\Source\Server\Internal\BM\EngWBLib\BMM10-GD.i.cs:line 3394
at Erp.Services.BO.EngWorkBenchSvc.ECOMtlAfterUpdate() in C:\_releases\ERP\ERP10.2.700.28\Source\Server\Services\BO\EngWorkBench\EngWorkBench.cs:line 10537
at Erp.Services.BO.EngWorkBenchSvc.OnRowEvent(DataTableEventType type, String tableName, IceRow row) in C:\_releases\ERP\ERP10.2.700.28\Source\Server\Services\BO\EngWorkBench\EngWorkBench.Designer.cs:line 801
at Ice.Services.Trace.TablesetProfilingCollector.DoRowEventTrace(String tableName, String methodName, Int32 rowCount, Action action) in C:\_releases\ICE\ICE3.2.700.28\Source\Framework\Epicor.Ice\Services\TablesetProfilingCollector.cs:line 138
at Ice.TablesetBound`3.CreateRow(IceDataContext dataContext, Int32 tableNum, IIceTable table, IceRow newTablesetRow, TablesetProfilingCollector parentTraceCollector) in C:\_releases\ICE\ICE3.2.700.28\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1185
at Ice.TablesetBound`3.WriteTable(IceDataContext dataContext, Int32 tableIndex, IIceTable table, TablesetProfilingCollector parentTraceCollector) in C:\_releases\ICE\ICE3.2.700.28\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 971
at Ice.TablesetBound`3.InnerUpdate[TUpdater](IceDataContext dataContext, TFullTableset tableset) in C:\_releases\ICE\ICE3.2.700.28\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 880
at Erp.Services.BO.EngWorkBenchSvc.Update(EngWorkBenchTableset& ds) in C:\_releases\ERP\ERP10.2.700.28\Source\Server\Services\BO\EngWorkBench\EngWorkBench.Designer.cs:line 4931
at Erp.Services.BO.EngWorkBenchSvcFacade.Update(EngWorkBenchTableset& ds) in C:\_releases\ERP\ERP10.2.700.28\Source\Server\Services\BO\EngWorkBench\EngWorkBenchSvcFacade.cs:line 6686
at EFx.PartGeneration.Implementation.CreatePartImpl.<>c__DisplayClass6_0.<Run>b__1(EngWorkBenchSvcContract hEWB)
at Epicor.Functions.FunctionBase`3.CallService[TService](Action`1 action) in C:\_Releases\ICE\ICE3.2.700.0\Source\Server\Internal\Lib\Epicor.Functions.Core\FunctionBase.Plugins.cs:line 60
at EFx.PartGeneration.Implementation.CreatePartImpl.Run()
at Epicor.Functions.FunctionBase`3.Run(TInput input) in C:\_Releases\ICE\ICE3.2.700.0\Source\Server\Internal\Lib\Epicor.Functions.Core\FunctionBase.cs:line 75
at Epicor.Functions.FunctionRestAdapter`2.Run(IFunctionRestHost host, JObject input) in C:\_Releases\ICE\ICE3.2.700.0\Source\Server\Internal\Lib\Epicor.Functions.Core\FunctionRestAdapter.cs:line 46
at Epicor.RESTApi.Functions.Controllers.EpicorFunctionController.Post(Boolean production, String company, String library, String function, JObject data) in C:\_Releases\ICE\ICE3.2.700.0\Source\Server\Internal\RESTApi.Plugins\Epicor.RESTApi.EFxPlugin\Controllers\EpicorFunctionController.cs:line 69
at lambda_method(Closure , Object , Object[] )
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass6_2.<GetExecutor>b__2(Object instance, Object[] methodParameters)
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary`2 arguments, CancellationToken cancellationToken)
