Jessi,
Your email saying 405a wasn't calculating earned hrs right in LaborDtl scared me a little so I rechecked today.
All Op labor reporting types we use (backflush, quantity & time & quantity) produced accurate (to +/-.01) calculated earned hrs with the pc/hr production rates (and as of today) fixed time per OP types we use in methods.
Same was true for jobs the system created/completed using KanBan Receipts.
(About 20,000 LaborDtl/JobOper/JobOpDtl linked records dumped into excel with a formula to calc earned hrs per help definitions matched the earned hrs in LaborDtl.)
...Could be your use of Minutes/pc instead of pc's/hr causing your issues.
Rob
Rob
--- On Wed, 2/11/09, Jessi Utecht <jessi.utecht@...> wrote:
> From: Jessi Utecht <jessi.utecht@...>
> Subject: Re: [Vantage] Re: Earned Hours
> To: vantage@yahoogroups.com
> Date: Wednesday, February 11, 2009, 8:43 PM
> we are on 405a and I would beg to differ on this.
> Â
> From: Robert Brown <robertb_versa@...>
> Sent: Wednesday, February 11, 2009 3:41:29 PM
> Well if it is any comfort, on 405a, the Earned Hours
> 'math' seems to be quite accurate.
> Can't attest to later versions.
> Rob
> --- On Wed, 2/11/09, bpbuechler <pbuechler@uvcolor.
> com> wrote:
> From: bpbuechler <pbuechler@uvcolor. com>
> Subject: [Vantage] Re: Earned Hours
> To: vantage@yahoogroups .com
> Date: Wednesday, February 11, 2009, 1:10 PM
> If you open the help on the Job Tracker - Labor
> Transactions it
> spells it out.
> Earned Hours
> Earned hours are defined as the number of hours it should
> have taken
> to produce the job quantities reported, based on the
> entered
> estimates. Earned Hours are used in various plant
> performance
> measurements, such as efficiency and overage.
> In general, the calculations for Earned Hours for a labor
> detail
> record are as follows:
> For Production:
> If the Run quantity > 0: EarnedHrs = EstProdHours /
> RunQty x LaborQty
> If the Production Standard is fixed hours: EarnedHrs <=
> EstSetHours –
> ActSetHours + SetReworkHours – Burden Hours for this
> labor detail
> record
> If the operation quantity = 1: EarnedHrs = Operation Hrs
> Remaining
> (EstProdHours - ActProdHours) or Hours Worked (BurdenHrs),
> whichever
> is less
> Setup is a little different. It is an evaluation of Setup
> as a
> whole; whereas productionis qty report / labor hrs for each
> time you
> report qty. Setup Earned Hours is only evaluated when setup
> is
> marked complete.
> For Setup:
> Setup Not Complete: EarnedHrs = EstSetHours x
> SetupPctComplete or
> ActSetupHours, whichever is less
> Setup Complete: EarnedHrs = EstSetHours – ActSetHours +
> SetReworkHours – Burden Hours for this labor detail
> record
> Thanks
> Patty Buechler
> --- In vantage@yahoogroups .com, Jessi Utecht
> <jessi.utecht@ ...> wrote:
> > I am trying to understand how to calculate Earned
> hours.
> > Can someone help me figure this out? It seems as
> though when we
> have a operation that is minutes/piece we get incorrect
> calculations,
> but if the operation is listed as fixed hours then it seems
> to
> calculate just fine.
> > The Epicor help does not explain Earned hours very
> well and was
> hoping somone could help me understand this better.
> Useful links for the Yahoo!Groups Vantage Board are: (
> Note: You must have already linked your email address to a
> yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for
> Report Builder and Crystal Reports and other
> 'goodies', please goto:
> (3) To view links to Vendors that provide Vantage services
> goto: http://groups.yahoo.com/group/vantage/linksYahoo!
> Groups Links
