E9041, Multiple entry programs?
It's a minor inconvenience for the extra features of it. I just wanted to make sure it was designed that way and I wasn't doing something incorrectly, so thank you for that clarification.
--- In vantage@yahoogroups.com, "Jeff Greenaway" wrote:
> Nick,
> You need to add the customization to each menu item through Menu
> Maintenance. On one hand, this seems to be a pain. On the other side, it
> can give you some flexibility.
> As one example, you might have a customization that applies to one set of
> users but not another so you can have two versions of the same menu item for
> the two different users sets. In some instances I like it better than
> building the user group logic into the customization, as going forward the
> person doing menu security changes can adjust the access in Menu Maint and
> not have to go into the customization.
> Regards,
> Jeff
> Jeff Greenaway
> Consulting CIO/ERP Consultant
> jeffgreenaway@...
> www.cio-ondemand.com
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> nskrede@...
> Sent: Wednesday, February 13, 2013 8:14 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] E9041, Multiple entry programs?
> Â
> I'm adding customizations, and noticed that my JobEntry custs WEREN'T
> showing when I navigated to the JobEntry program from
> ProjectManagement-->GeneralOperations, but they WERE when I navigated there
> from ProductionManagement-->GeneralOperations.
> In MenuMaintenance they are listed as the same program, so applying a
> customization should apply it to where ever that program is located
> shouldn't it? That's just my logic.
> Thanks
> -Nick
I'm adding customizations, and noticed that my JobEntry custs WEREN'T showing when I navigated to the JobEntry program from ProjectManagement-->GeneralOperations, but they WERE when I navigated there from ProductionManagement-->GeneralOperations.
In MenuMaintenance they are listed as the same program, so applying a customization should apply it to where ever that program is located shouldn't it? That's just my logic.
-Nick
Nick,
Regards,
Jeff
Jeff Greenaway
jeffgreenaway@...
nskrede@...
Â
-Nick
