E9 Using Alias Tables in BAQs
What version of epicor are you on?
I have done it successfully in 9.04.506 but since we upgraded to patch 507A and had to get a one-off from epicor to make it possible to link more than one table it didn't work anymore with alias tables.
I submitted a call to epicor about this.
Ephraim Feldman
Programmer / Analyst
Axis Lighting
Sender: vantage@yahoogroups.com
Date: Fri, 18 Feb 2011 14:48:29
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: [Vantage] E9 Using Alias Tables in BAQs
Hello,
Has anyone successful added a table to a BAQ more than one time (created
a table alias)?
I've tried a couple of times now and each time, the fields from the
table alias are always blank even though I know the linked fields have
matching values.
If you have done this successfully, is there a trick to it?
Thanks.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Hello,
a table alias)?
matching values.
Thanks.
You can do this in 9 and above
From: vantage@yahoogroups.com on behalf of Joe Rojas
Sent: Fri 2/18/2011 2:48 PM
Hello,
a table alias)?
matching values.
Thanks.
jrojas@... <mailto:jrojas%40matsinc.com> | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
Thanks Sean.
I know that it can be done but I was wondering if anyone has
successfully done it.
Of Sean McDaniel
Sent: Friday, February 18, 2011 3:12 PM
To: vantage@yahoogroups.com; vantage@yahoogroups.com
Subject: RE: [Vantage] E9 Using Alias Tables in BAQs
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> on
behalf of Joe Rojas
Hello,
a table alias)?
matching values.
Thanks.
Good Day Sean:
I have done it. No real trick. I always include Company as one of
the fields to link the tables.
Watch out for the direction of the Link, and sometimes you need an
outer join.
Sample attached. Also attached is the export of the BAQ file. It is
a rather complicated one.
It is a where-used for a JOB so we can find out what Sub-Assembly it
is in because some of our JOBs have many many sub-assemblies.
Sun went live on 11/29
in Epicor 9, 9.05.601B SQL-Unidata
Sun was previously on M2K (Manage-2000) 7.0 SP 5 (Informix)
len.hartka@...
Of Joe Rojas
Sent: Friday, February 18, 2011 3:42 PM
Thanks Sean.
Behalf
Of Sean McDaniel
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ;
behalf of Joe Rojas
Hello,
a table alias)?
matching values.
Thanks.
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
I have done it successfully on 9.05 myself and cant think of any peculiarities. If you let me know the details of what you are trying to achieve I might be able to help further.
Aman
--- In vantage@yahoogroups.com, "Len Hartka" <len.hartka@...> wrote:
> Good Day Sean:
> outer join.
> len.hartka@...
> Of Joe Rojas
> Thanks Sean.
> Behalf
> Of Sean McDaniel
> behalf of Joe Rojas
> Hello,
> a table alias)?
> matching values.
> Thanks.
