Hi All,
I posted a message not too long ago where I was trying to create a BPM
that would sync a UD field on QuoteHed to Project ID on QuoteDtl.
I was able to create the BPM and the only downside to it is that I have
to refresh the quote in order to see the change on the quote lines
because I had to update QuoteDtl directly because there are not always
records in ttQuoteDtl.
The refresh issue is a little annoying but not really a big deal.
Now I'm trying to do the same thing but for Sale Orders.
Taking the same approach as the BPM for Quotes, I found that the Sale
Order screen behaves differently.
As soon as the SalesOrder.Update method completes (I'm putting my code
in pre-processing) I get the "Record has been changed...please refresh"
message.
This wouldn't be so bad but it does an undo on the change I made at the
header level so now the value at the lines are correct but the header
has the "old" value.
So, my question is...is there a way to mark the sale order lines as
"dirty" so that when SalesOrder.Update executes the ttOrderDtl tables
will always have records?
If I can get this happen, then my code will work properly because I
won't have to directly update OrderDtl.
Thanks!
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-1264 | fax: 781-341-5694
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
message.
Thanks!
