E9 to E10 Migration: Start over using the Interim DB
In your case, did you just manually repopulate ICE.ICEVer to get past this issue?
My first call to Epicor resulted in support not know of this issue.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
addr: 37 Shuman Ave | Stoughton | Ma | 02072-3734
jrojas@... | www.matsinc.com
Ask us about our clean, green and beautiful matting and flooring
[cid:56cad0.png@52224cca.48842ad7]
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Sent: Tuesday, September 30, 2014 8:58 AM
Subject: [Vantage] Re: E9 to E10 Migration: Start over using the Interim DB
I can tell you from personal experience that all of the issues described here happened to me (both the IceVer being messed up, and the Admin Console stopped working then until I re-installed it) and I am doing a SQL to SQL conversion. We were never on a Progress database.
Glad to hear others are seeing this, and that Epicor is aware. Is 10.1 still predicted to be out next month?
Hi All,
So I got to the end of the E9 to E10 migration process only to run into an issue when trying to rebuild that data model.
It looks like something happened way back in the beginning when the E10 database was created and it did not have an App version specified and the ICE version was 3.0.6 even though I never install E10 600.
As a result, I am being told I have to start the entire migration process over.
After creating the new E10 DB, the ICE version and App version look good.
My question is, has anyone had to start over and tried to reuse the existing interim DB instead of starting at the very beginning, which would include migrating the Progress data to the interim DB. This step, step 10, took me 17 hours and I really don’t want to have to run that step again.
Epicor says there is no other option but did note that it is because they never tried this in house.
I am attempting to do this by skipping step 10 and 100, which clearly seem to be related to just working with E9 data.
I’ll report back in with how it went, but I’m hoping that someone has done the say to I can feel confident with the resulting E10 DB.
[cid:1e0f37.png@bfb0b4f3.499a5edf]
Joe,
I had the problem with my second attempt at a conversion.  I went into the demo db and copy the records out of the ICVer table.  They admin server liked what I put in there and started the conversion process.
I hope I don't have to do that on cut over weekend, but I figure it was good enough to get me through the process for testing.
Tom Osen
IT Manager
Water Gremlin Co.
I had to do the same thing. Ice.ICEVer table was empty after migration.
From: "tom.epicor.grp@... [vantage]" <vantage@yahoogroups.com>
Sent: Friday, September 26, 2014 5:40 PM
Joe,
Tom Osen
IT Manager
Water Gremlin Co.
Oh man. I really wish Epicor knew about this.
I already blew away my DB and started over.
On top of that, I’m having problems starting over!
[cid:3e3ad3.png@c91ea80b.4e9abaf9]
Sent: Monday, September 29, 2014 8:02 AM
Subject: Re: [Vantage] Re: E9 to E10 Migration: Start over using the Interim DB
Joe,
Tom Osen
IT Manager
Water Gremlin Co.
Is this an issue only for the Progress to SQL migration?
Brinda
On Sep 29, 2014, at 8:41 AM, Joe Rojas jrojas@... [vantage] <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-25479543ygrp-text">
  <p>Oh man. I really wish Epicor knew about this.
Joe,
Tom Osen
IT Manager
Water Gremlin Co.
</div>
I can only speak for me but that is what I’m doing. Progress to SQL.
[cid:16884c.png@23601595.4a9afd38]
Sent: Monday, September 29, 2014 8:48 AM
Brinda
On Sep 29, 2014, at 8:41 AM, Joe Rojas jrojas@...<mailto:jrojas@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
jrojas@...<mailto:jrojas@...> | www.matsinc.com<http://www.matsinc.com>
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
From: "tom.epicor.grp@...<mailto:tom.epicor.grp@...> [vantage]" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>
Joe,
Tom Osen
IT Manager
Water Gremlin Co.
Joe,
I think this is only a problem with the .2 service pack.  I reloaded the .1 and the new db creation worked fine.
I am waiting on Epicor to confirm this error with the .2 service back.
Tom Osen
IT Manager
Water Gremlin Co.
That would makes sense. I’ve only been working with .2
If it happens again on this next migration, I’ll give them a call too.
[cid:190da8.png@88826369.4b99ef51]
Sent: Monday, September 29, 2014 4:15 PM
Subject: RE: [Vantage] Re: E9 to E10 Migration: Start over using the Interim DB
Joe,
Tom Osen
IT Manager
Water Gremlin Co.
Try uninstalling the Epicor administration Console and re-installing.
Be sure to delete all the files under C:\Program Files (x86)\Common Files\Epicor Software Corporation\Epicor ERP Administration Console
The re-attach the database to the console.
Epicor knows of this problem and is moving away from the MMC console by 10.1
Regards,
Chris Wineinger
ERP Specialist
Interior Systems, Inc.
241 N Broadway Ste 600
Milwaukee, WI 53202
Office # 414.224.0957 X2051
Direct# 414.847.0701
Cell # 414.840.6594
IT related problem? Contact helpdesk@...
