I’m sorry, that was actually a terrible example…
- Left side would be the dataset column from EpiBOName “CustCnt”, so CustNum
- Right side would be the column from your QuoteHed dataview, which is CustNum
There are two syntax types you can use. Here is the first:
- CustNum = ‘?[CustNum,0]’ (The “,0” is used to default if the CustNum is not found)
The second way is to define a parameter and assign it in the EpiFiltersParams section. This method has to do with reusable combos:
- CustNum = ‘?{MyParameter,0}’ (squiggly brackets)
In the EpiFiltersParams section you can then define the column to use:
- MyParameter = ‘?[CustNum]’
Similar to below:
