E9: Removing a custom sheet - some code remains
Thanks Rob.
I did look there and I didn't see anything.
If I export the customization, I can see the references there. I thought
about deleting from there and then reimporting the customization but I
wasn't sure how successful I would be with doing it that way.
Of Rob Bucek
Sent: Thursday, December 05, 2013 11:26 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] E9: Removing a custom sheet - some code remains
Is it possible you might see a reference under the custom xml editor? If
so you could remove it from there..
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-4832
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Of Jose Gomez
Sent: Thursday, December 05, 2013 8:52 AM
To: Vantage
Subject: Re: [Vantage] E9: Removing a custom sheet - some code remains
Not so much you if this is the only "code" modification and the rest is
just UI. You can check Create New Code Layer that might do it for you
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
[Image removed by sender.]<http://www.linkedin.com/in/josecgomez> [Image
removed by sender.] <http://www.facebook.com/josegomez> [Image removed
by sender.] <http://www.google.com/profiles/jose.gomez> [Image removed
by sender.] <http://www.twitter.com/joc85> [Image removed by sender.]
<http://www.josecgomez.com/professional-resume/> [Image removed by
sender.] <http://www.josecgomez.com/feed/> [Image removed by sender.]
<http://www.usdoingstuff.com>
On Thu, Dec 5, 2013 at 9:49 AM, Joe Rojas
<jrojas@...<mailto:jrojas@...>> wrote:
Hello,
I have an embedded dashboard that I added to Sales Order Tracker using
the Sheet Wizard.
I need to remove it and then read it with different options.
I removed the sheet, saved the customization, closed the script editor,
closed the tracker, reopened everything and then attempted to add it
back.
When I added the sheet back and then compiled the code, it told me that
there was already a reference to this sheet.
After removing the sheet again, I check off "All Code" and I did see
that the reference was still there. The wizard did not clean up all the
code.
I can add the sheet back with a different name to move past this but I
was wondering if there was some way to remove the old code?
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291<tel:781-573-0291> | cell:
781-408-9278<tel:781-408-9278> | fax: 781-232-5191<tel:781-232-5191>
jrojas@...<mailto:jrojas@...> |
www.matsinc.com<http://www.matsinc.com> Ask us about our clean, green
and beautiful matting and flooring
This message is intended only for the individual named. If you are not
the named addressee you should not disseminate, distribute or copy this
e-mail. Please notify the sender immediately by e-mail if you have
received this e-mail by mistake. Please note that any views or opinions
presented in this email are solely those of the author and do not
necessarily represent those of the company.
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Hello,
the Sheet Wizard.
back.
code.
Not so much you if this is the only "code" modification and the rest is just UI. You can check Create New Code Layer that might do it for you
Jose C Gomez
Software Engineer
E: jose@...
     Â
On Thu, Dec 5, 2013 at 9:49 AM, Joe Rojas <jrojas@...> wrote:
Â
<div>
  <p>Hello,<br>
the Sheet Wizard.
back.
code.
jrojas@… | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
</div>
<div style="color:#fff;min-height:0;"></div>
There is some other code not much.
If you don't mind, could you explain a little bit about what "Create New
Code Layer" does?
Of Jose Gomez
Sent: Thursday, December 05, 2013 9:52 AM
To: Vantage
Jose C Gomez
Software Engineer
E: jose@...
http://www.josecgomez.com <http://www.josecgomez.com>
<http://www.josecgomez.com/feed/> <http://www.usdoingstuff.com>
Hello,
the Sheet Wizard.
back.
code.
I do'nt have inside info but from my experience it leaves all the UI elements in place but gives you a 100% fresh code base. It was made so that technically you could have a custmoization on top of another but it never worked well. Its used between the different layes (Base, Epicor, Customization and sometimes CSG inbetween)
Jose C Gomez
Software Engineer
E: jose@...
     Â
On Thu, Dec 5, 2013 at 9:55 AM, Joe Rojas <jrojas@...> wrote:
Â
<div>
  <p>There is some other code not much.<br>
Code Layer" does?
Of Jose Gomez
To: Vantage
Jose C Gomez
Software Engineer
E: jose@...
Hello,
the Sheet Wizard.
back.
code.
</div>
Thanks Jose.
I will give that a shot.
Of Jose Gomez
Sent: Thursday, December 05, 2013 9:57 AM
To: Vantage
Jose C Gomez
Software Engineer
E: jose@...
Code Layer" does?
Of Jose Gomez
To: Vantage
Jose C Gomez
Software Engineer
E: jose@...
Hello,
the Sheet Wizard.
back.
code.
Is it possible you might see a reference under the custom xml editor? If so you could remove it from there..
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
To: Vantage
Jose C Gomez
Software Engineer
[Image removed by sender.]<http://www.linkedin.com/in/josecgomez> [Image removed by sender.] <http://www.facebook.com/josegomez> [Image removed by sender.] <http://www.google.com/profiles/jose.gomez> [Image removed by sender.] <http://www.twitter.com/joc85> [Image removed by sender.] <http://www.josecgomez.com/professional-resume/> [Image removed by sender.] <http://www.josecgomez.com/feed/> [Image removed by sender.] <http://www.usdoingstuff.com>
On Thu, Dec 5, 2013 at 9:49 AM, Joe Rojas <jrojas@...<mailto:jrojas@...>> wrote:
Hello,
the Sheet Wizard.
back.
code.
dir: 781-573-0291<tel:781-573-0291> | cell: 781-408-9278<tel:781-408-9278> | fax: 781-232-5191<tel:781-232-5191>
jrojas@...<mailto:jrojas@...> | www.matsinc.com<http://www.matsinc.com> Ask us about our clean, green and beautiful matting and flooring
