I was able to figure it out when done at runtime.
Dimension both the Epicor element to be moved and the new parent with the guid.
Add the element to be moved to the control group of the parent
Parentelement.controls.add(childelement)
I then had to play around with location, but it worked.
Tom Christie | Information Technology Manager | AGM Container Controls, Inc.<http://www.agmcontainer.com/> | tchristie@...<mailto:tchristie@...> | t: 520.881.2130 ext 2176
Sent: Wednesday, July 2, 2014 10:09 PM
Subject: RE: [Vantage] E9: Moving an Epicor tab or groupbox
Tom,
When you open customization maintenance, display the custom code, there's a
place in there where I believe you can change the parent element. From
memory, I recall that you'd need to know the GUID of the new parent and
replace the parent of the group box.
I'd HIGHLY recommend that you backup your customization in case something
goes wrong.
Kevin Simon
Sent: Wednesday, July 02, 2014 7:05 PM
Subject: [Vantage] E9: Moving an Epicor tab or groupbox
So, I would like to move a particular groupbox from the Quote header to the
Quote Summary screen. It would be wonderful if I could move it and not have
to recreate all the elements on it. Is this possible?
Regards,
Inc. <http://www.agmcontainer.com/> | tchristie@...
Tom,
goes wrong.
Kevin Simon
Regards,
