After trouble with some corrupted system tables I'm now close to the point where I'll have converted my Vantage 8 data (Progress) to Epicor 9.05.607A (Progress). The next step will be to dump the data out of E9 Progress and then into E9 MS SQL.
My problem here is the ASCII Dump and Load 'kit' for Epicor 9.05.6xx is presuming that you'll dump from Progress and load back into Progress.
Do Epicor produce a document for dumping from Progress and loading into MS SQL ?. If not what have others here done ?.
Thanks.
Thanks.
