E9? Custom Screen error- how get into it to fix
Good Day Stephen and Gavin:
Thanks for the response.
Since the HTML code is Greek to me, is there no way to get back to
the GUI customization interface?
len.hartka@...
Of Stephen Edginton
Sent: Tuesday, February 16, 2010 6:58 PM
Subject: RE: [Vantage] E9? Custom Screen error- how get into it to fix
There can be a number of reasons for this, one example is incorrect code
in the initialize code event A change they made from 803, when you now
test code it doesn't execute this method (during test). So it is easier
to get into this type of mess where you can't get back in.
To fix the use the utilities -> customisation maintenance menu to export
your customisation to XML, then use a text editor to comment out the
code in your initialize code method or newly changed parts.
If it is not a code related error then it is a property of some kind
that is causing this issue, you can remove these section by section or
look further in the detail to establish the cause.
Regards,
Stephen
Behalf
Of Len Hartka
Sent: 16 February 2010 23:50
Subject: [Vantage] E9? Custom Screen error- how get into it to fix
Good Day:
Sun Is on M2K (Informix) but,
Going to: Epicor 9, 9.04.505B ( maybe 9.05), SQL (live 7/1/2010-
maybe 8/1/10)
I was doing the training on Order-Entry screen Embedded
customization. I exited and now when I try to go in I get an error (
seee below) and it will not open in developer mode. It opens the 'base'
version. So, I cannot fix it.
How do you fix a custom screen when I can't get it to open in
developer mode?
Developer Mode >> click on Order-Entry >> get screen to select
Base or custom >> click on custom name >> get error box >> no matter
what you do at that point, it just opens the Base Screen.
I also tried " Reset Layouts to Base", but since I was in the Base
screen, that did not work.
I think I could delete the custom, but then I would loose all my
work. I guess I also need to figure out how to save back-up copies.
len.hartka@... <mailto:len.hartka%40sunautomation.com>
Sun Automation Group
Celebrating
25 Years of Service
to the Corrugated Industry
This e-mail and any attachments may contain proprietary and/or
confidential information. If you are not the intended recipient, please
notify the sender immediately by reply e-mail or at 410-472-2900 and
then delete the message without using, disseminating, or copying this
message or any portion thereof. With e-mail communications you are urged
to protect against viruses.
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
Good Day:
maybe 8/1/10)
developer mode?
len.hartka@...
Celebrating
25 Years of Service
Regards,
Stephen
Of Len Hartka
Good Day:
maybe 8/1/10)
developer mode?
Celebrating
25 Years of Service
