Bam files go on the server in this directory. \\machine\Epicor905\Server\ud
In the yahoo group file section is a document on the entire setup process that I used to get me started.
BAM Setup - BAM_Alert_OrderRel_DropShip.zip
https://xa.yimg.com/df/vantage/BAM_Alert_OrderRel_DropShip.zip?token=oytDiLgcWSNuu3nsFnzrJnFfQWc81kaTxEw9qz1nWgKN1GNsK47l0ZbFNUMaucerZVbAHg2DsrkEIguTVHivpJAu30lqgIeKQYoIdJuAF4PJnzu39ItT8BBT9Jo1QA&type=download
Some BAM Examples are also there.
https://groups.yahoo.com/neo/groups/vantage/files/%20%20%20version%209.0%20files/BAM/
Below is a bam I use on Invoicing. Change InvcHead to CashHead and it should be ready to debug. Check the server log for errors. If you don’t want the invoices paid, just that there was a payment remove the Dtl for each.
Greg
{ud/GlbAlert.i &TableName = "InvcHead"}
ASSIGN SendEmail = FALSE.
/* format Email Text */
define variable EmailAddress as Character no-undo initial '':U.
define variable UserName as Character no-undo initial '':U.
define variable vFrom as character no-undo initial '':U.
define variable vTo as character no-undo initial '':U.
define variable vCC as character no-undo initial '':U.
define variable vSubject as character no-undo initial '':U.
define variable vBody as character no-undo initial '':U.
/* Find InvcHead where InvcMisc.Company = InvcHead.Company and InvcMisc.InvoiceNum = InvcHead.InvoiceNum. */
Find First Customer where InvcHead.Custnum = Customer.CustNum.
Find First UserFile where UserFile.DCDUserID = DCD-UserID no-error.
message " In alert on misc charge" + string(InvoiceHead.InvoiceNum).
Assign vBody = "New Misc Charge" +
"~n~n~tCustomer " + Customer.CustID +
"~n~n~tName " + Customer.Name.
For Each InvcDtl where InvcHead.Company = Invcdtl.Company and InvcHead.InvoiceNum = InvcDtl.InvoiceNum.
Assign vBody = vBody +
"~n~n~tItem " + InvcDtl.PartNum + "~tDesc. " + InvcDtl.LineDesc.
End.
For Each InvcMisc where InvcMisc.Company = InvcHead.Company and InvcMisc.InvoiceNum = InvcHead.InvoiceNum.
"~n~tMisc Charge " + InvcMisc.Description + "~tAmount " + TRIM(string(InvcMisc.MiscAmt,"$>>>,>>>,>>9.99")).
assign SendEmail = true.
End.
assign vTO = "info@...".
assign vTO = "email@...;email@...;email@..."
vCC = "info@...;".
assign EMAIL-From = UserFile.EmailAddress.
EMAIL-To = vTO.
EMAIL-CC = vCC + EMAIL-From.
assign EMAIL-Subject = 'Epicor Misc Charge: ' + Customer.CustID + " - " + Customer.Name.
assign EMAIL-Text = vBody.
Sent: Wednesday, March 23, 2016 8:56 AM
Subject: RE: [Vantage] Re: E9: BPM: E-mail alert on payment from specific CustID
Thanks Greg.
If you have an alert program example in mind that you can point me to, that would be a big help.
Where would you recommend these alert programs live?
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
