It’s a known issue. There is a on off you can get from support.
Greg
BAQRD issues at 9.05.702 - this one-off fixes both SCR 121789 and 123305.
Both issues are with Actions > Test Report Form in the BAQ Report Designer Tool.
SCR 121789 - - BAQ Designer - <"Record not found" message from Test Report Form option in BAQ Report designer.> SCR 123305 - BAQ Report Designer Test report dialog displays unrelated form.
WHAT THE SCR FIX DOES:
You need to add new menu item using menu maintenance Menu ID: BAQRep
Module: UD
Security ID: SEC00
Parent Menu ID Processes
Order Sequence: 120
Type: Non Menu Item
Icon: Entry
Program: Epicor.Mfg.UIRpt.BAQReport.dll
Client
Epicor.Mfg.UI.DynamicReportDesigner.dll
HOW TO APPLY THE SCR FIX
Please test before applying to production.
Steps to apply fix:
Client
1) Make a backup copy of the Epicor.Mfg.UI.DynamicReportDesigner.dll file in the Client directory.
2) Make a backup copy of the Epicor.Mfg.UIRpt.BAQReport.dll file in the Client directory.
3) Copy this new Epicor.Mfg.UI.DynamicReportDesigner.dll file into the Client Directory.
4) Copy this new Epicor.Mfg.UIRpt.BAQReport.dll file into the Client Directory.
Sent: Saturday, May 14, 2016 11:41 AM
To: yahoogroups
Subject: [Vantage] E9- BAQ Report Designer
Happy Saturday!
I don't know if anyone's run into this issue.
ERP: Epicor 9.05.702A
Problem:
BAQ Report Designer won't produce the correct XML file from Test Report Form for a Crystal Report.
Details:
I created a BAQ for Job Operations. Saved the BAQ as SII-JobOpDtl
Opened BAQ Report Designer:
Report ID: JobOpDtl
Description: Job Operation Detail Report
BAQ ID: SII-JobOpDtl
Form Title: Job Operation Detail Report
Crystal Report: JobOpDtl.rpt
Clicked Actions --> Test Report Form and I get the DMR Detail Report I created earlier. It doesn't process the JobOpDtl.rpt to give me the desired XML file I require to create a report. It does create a Crystal Report JobOpDtl.rpt though and puts into the Reports folder.
Has anyone encountered this issue and have a resolution? Any help would be greatly appreciated.
Thank you,
Jonathan Lang
I.T Manager
Database Engineer
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
<div id="ygrps-yiv-1332729893yiv9240652791ygrp-text">
<div>
To: yahoogroups
</div>
<div class="ygrps-yiv-1332729893yiv9240652791yqt0968053590" id="ygrps-yiv-1332729893yiv9240652791yqt24029"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-mkp #ygrps-yiv-1332729893yiv9240652791hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-mkp #ygrps-yiv-1332729893yiv9240652791ads {
margin-bottom:10px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-mkp .ygrps-yiv-1332729893yiv9240652791ad {
padding:0 0;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-mkp .ygrps-yiv-1332729893yiv9240652791ad p {
margin:0;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-mkp .ygrps-yiv-1332729893yiv9240652791ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-sponsor #ygrps-yiv-1332729893yiv9240652791ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-sponsor #ygrps-yiv-1332729893yiv9240652791ygrp-lc #ygrps-yiv-1332729893yiv9240652791hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-sponsor #ygrps-yiv-1332729893yiv9240652791ygrp-lc .ygrps-yiv-1332729893yiv9240652791ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791activity span {
font-weight:700;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791activity span span {
color:#ff7900;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791activity span .ygrps-yiv-1332729893yiv9240652791underline {
text-decoration:underline;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 .ygrps-yiv-1332729893yiv9240652791attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 .ygrps-yiv-1332729893yiv9240652791attach div a {
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 .ygrps-yiv-1332729893yiv9240652791attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 .ygrps-yiv-1332729893yiv9240652791attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 .ygrps-yiv-1332729893yiv9240652791attach label a {
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 .ygrps-yiv-1332729893yiv9240652791bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 .ygrps-yiv-1332729893yiv9240652791bold a {
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 dd.ygrps-yiv-1332729893yiv9240652791last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 dd.ygrps-yiv-1332729893yiv9240652791last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 dd.ygrps-yiv-1332729893yiv9240652791last p span.ygrps-yiv-1332729893yiv9240652791yshortcuts {
margin-right:0;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 div.ygrps-yiv-1332729893yiv9240652791attach-table div div a {
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 div.ygrps-yiv-1332729893yiv9240652791attach-table {
width:400px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 div.ygrps-yiv-1332729893yiv9240652791file-title a, #ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 div.ygrps-yiv-1332729893yiv9240652791file-title a:active, #ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 div.ygrps-yiv-1332729893yiv9240652791file-title a:hover, #ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 div.ygrps-yiv-1332729893yiv9240652791file-title a:visited {
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 div.ygrps-yiv-1332729893yiv9240652791photo-title a, #ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 div.ygrps-yiv-1332729893yiv9240652791photo-title a:active, #ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 div.ygrps-yiv-1332729893yiv9240652791photo-title a:hover, #ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 div.ygrps-yiv-1332729893yiv9240652791photo-title a:visited {
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 div#ygrps-yiv-1332729893yiv9240652791ygrp-mlmsg #ygrps-yiv-1332729893yiv9240652791ygrp-msg p a span.ygrps-yiv-1332729893yiv9240652791yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 .ygrps-yiv-1332729893yiv9240652791green {
color:#628c2a;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 .ygrps-yiv-1332729893yiv9240652791MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 o {
font-size:0;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791photos div {
float:left;width:72px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791reco-category {
font-size:77%;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791reco-desc {
font-size:77%;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 .ygrps-yiv-1332729893yiv9240652791replbq {
margin:4px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-mlmsg select, #ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 input, #ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-mlmsg pre, #ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 code {
font:115% monospace;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-mlmsg #ygrps-yiv-1332729893yiv9240652791logo {
padding-bottom:10px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-msg p#ygrps-yiv-1332729893yiv9240652791attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-reco #ygrps-yiv-1332729893yiv9240652791reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-sponsor #ygrps-yiv-1332729893yiv9240652791ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-sponsor #ygrps-yiv-1332729893yiv9240652791ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-sponsor #ygrps-yiv-1332729893yiv9240652791ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1332729893 #ygrps-yiv-1332729893yiv9240652791 #ygrps-yiv-1332729893yiv9240652791ygrp-vital ul li:last-child {
border-right:none !important;}
The form works if you deploy it, it is just wrong in test
Sent: Saturday, May 14, 2016 12:03 PM
Subject: Re: [Vantage] E9- BAQ Report Designer
Ahhh Snap! So I have to get the SCR from support first. That wastes my Saturday. There isn't a work around until then? Hahahaha
Jonathan Lang
I.T Manager
Database Engineer
On Saturday, May 14, 2016 10:51 AM, "Greg Payne gpayne@... [vantage]" <vantage@yahoogroups.com> wrote:
Greg
Module: UD
Security ID: SEC00
Order Sequence: 120
Type: Non Menu Item
Icon: Entry
Client
Steps to apply fix:
Client
To: yahoogroups
Happy Saturday!
Problem:
Details:
Report ID: JobOpDtl
Thank you,
Jonathan Lang
I.T Manager
Database Engineer
Jonathan Lang
I.T Manager
Database Engineer
Greg
Module: UD
Security ID: SEC00
Order Sequence: 120
Type: Non Menu Item
Icon: Entry
Client
Steps to apply fix:
Client
To: yahoogroups
Happy Saturday!
Problem:
Details:
Report ID: JobOpDtl
Thank you,
Jonathan Lang
I.T Manager
Database Engineer
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
<div id="ygrps-yiv-456237670yiv1753201938ygrp-text">
<div>
To: yahoogroups
</div>
<div class="ygrps-yiv-456237670yiv1753201938yqt6974306943" id="ygrps-yiv-456237670yiv1753201938yqt98511"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-mkp hr {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-mkp #ygrps-yiv-456237670yiv1753201938hd {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-mkp #ygrps-yiv-456237670yiv1753201938ads {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-mkp .ygrps-yiv-456237670yiv1753201938ad {
padding:0 0;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-mkp .ygrps-yiv-456237670yiv1753201938ad p {
margin:0;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-mkp .ygrps-yiv-456237670yiv1753201938ad a {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-sponsor #ygrps-yiv-456237670yiv1753201938ygrp-lc {
font-family:Arial;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-sponsor #ygrps-yiv-456237670yiv1753201938ygrp-lc #ygrps-yiv-456237670yiv1753201938hd {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-sponsor #ygrps-yiv-456237670yiv1753201938ygrp-lc .ygrps-yiv-456237670yiv1753201938ad {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938actions {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938activity {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938activity span {
font-weight:700;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938activity span:first-child {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938activity span a {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938activity span span {
color:#ff7900;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938activity span .ygrps-yiv-456237670yiv1753201938underline {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 .ygrps-yiv-456237670yiv1753201938attach {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 .ygrps-yiv-456237670yiv1753201938attach div a {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 .ygrps-yiv-456237670yiv1753201938attach img {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 .ygrps-yiv-456237670yiv1753201938attach label {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 .ygrps-yiv-456237670yiv1753201938attach label a {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 .ygrps-yiv-456237670yiv1753201938bold {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 .ygrps-yiv-456237670yiv1753201938bold a {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 dd.ygrps-yiv-456237670yiv1753201938last p a {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 dd.ygrps-yiv-456237670yiv1753201938last p span {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 dd.ygrps-yiv-456237670yiv1753201938last p span.ygrps-yiv-456237670yiv1753201938yshortcuts {
margin-right:0;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 div.ygrps-yiv-456237670yiv1753201938attach-table div div a {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 div.ygrps-yiv-456237670yiv1753201938attach-table {
width:400px;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 div.ygrps-yiv-456237670yiv1753201938file-title a, #ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 div.ygrps-yiv-456237670yiv1753201938file-title a:active, #ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 div.ygrps-yiv-456237670yiv1753201938file-title a:hover, #ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 div.ygrps-yiv-456237670yiv1753201938file-title a:visited {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 div.ygrps-yiv-456237670yiv1753201938photo-title a, #ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 div.ygrps-yiv-456237670yiv1753201938photo-title a:active, #ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 div.ygrps-yiv-456237670yiv1753201938photo-title a:hover, #ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 div.ygrps-yiv-456237670yiv1753201938photo-title a:visited {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 div#ygrps-yiv-456237670yiv1753201938ygrp-mlmsg #ygrps-yiv-456237670yiv1753201938ygrp-msg p a span.ygrps-yiv-456237670yiv1753201938yshortcuts {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 .ygrps-yiv-456237670yiv1753201938green {
color:#628c2a;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 .ygrps-yiv-456237670yiv1753201938MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 o {
font-size:0;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938photos div {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938photos div div {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938photos div label {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938reco-category {
font-size:77%;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938reco-desc {
font-size:77%;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 .ygrps-yiv-456237670yiv1753201938replbq {
margin:4px;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-actbar div a:first-child {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-mlmsg {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-mlmsg table {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-mlmsg select, #ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 input, #ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 textarea {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-mlmsg pre, #ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 code {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-mlmsg * {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-mlmsg #ygrps-yiv-456237670yiv1753201938logo {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-msg p a {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-msg p#ygrps-yiv-456237670yiv1753201938attach-count span {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-reco #ygrps-yiv-456237670yiv1753201938reco-head {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-reco {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-sponsor #ygrps-yiv-456237670yiv1753201938ov li a {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-sponsor #ygrps-yiv-456237670yiv1753201938ov li {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-sponsor #ygrps-yiv-456237670yiv1753201938ov ul {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-text {
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-text tt {
font-size:120%;}
#ygrps-yiv-456237670 #ygrps-yiv-456237670yiv1753201938 #ygrps-yiv-456237670yiv1753201938ygrp-vital ul li:last-child {
<div id="ygrps-yiv-1916151949yiv7021788273ygrp-text">
<div>
To: yahoogroups
</div>
<div class="ygrps-yiv-1916151949yiv7021788273yqt5387397760" id="ygrps-yiv-1916151949yiv7021788273yqt54669"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-mkp hr {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-mkp #ygrps-yiv-1916151949yiv7021788273hd {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-mkp #ygrps-yiv-1916151949yiv7021788273ads {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-mkp .ygrps-yiv-1916151949yiv7021788273ad {
padding:0 0;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-mkp .ygrps-yiv-1916151949yiv7021788273ad p {
margin:0;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-mkp .ygrps-yiv-1916151949yiv7021788273ad a {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-sponsor #ygrps-yiv-1916151949yiv7021788273ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-sponsor #ygrps-yiv-1916151949yiv7021788273ygrp-lc #ygrps-yiv-1916151949yiv7021788273hd {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-sponsor #ygrps-yiv-1916151949yiv7021788273ygrp-lc .ygrps-yiv-1916151949yiv7021788273ad {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273actions {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273activity {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273activity span {
font-weight:700;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273activity span:first-child {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273activity span a {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273activity span span {
color:#ff7900;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273activity span .ygrps-yiv-1916151949yiv7021788273underline {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 .ygrps-yiv-1916151949yiv7021788273attach {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 .ygrps-yiv-1916151949yiv7021788273attach div a {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 .ygrps-yiv-1916151949yiv7021788273attach img {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 .ygrps-yiv-1916151949yiv7021788273attach label {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 .ygrps-yiv-1916151949yiv7021788273attach label a {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 .ygrps-yiv-1916151949yiv7021788273bold {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 .ygrps-yiv-1916151949yiv7021788273bold a {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 dd.ygrps-yiv-1916151949yiv7021788273last p a {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 dd.ygrps-yiv-1916151949yiv7021788273last p span {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 dd.ygrps-yiv-1916151949yiv7021788273last p span.ygrps-yiv-1916151949yiv7021788273yshortcuts {
margin-right:0;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 div.ygrps-yiv-1916151949yiv7021788273attach-table div div a {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 div.ygrps-yiv-1916151949yiv7021788273attach-table {
width:400px;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 div.ygrps-yiv-1916151949yiv7021788273file-title a, #ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 div.ygrps-yiv-1916151949yiv7021788273file-title a:active, #ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 div.ygrps-yiv-1916151949yiv7021788273file-title a:hover, #ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 div.ygrps-yiv-1916151949yiv7021788273file-title a:visited {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 div.ygrps-yiv-1916151949yiv7021788273photo-title a, #ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 div.ygrps-yiv-1916151949yiv7021788273photo-title a:active, #ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 div.ygrps-yiv-1916151949yiv7021788273photo-title a:hover, #ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 div.ygrps-yiv-1916151949yiv7021788273photo-title a:visited {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 div#ygrps-yiv-1916151949yiv7021788273ygrp-mlmsg #ygrps-yiv-1916151949yiv7021788273ygrp-msg p a span.ygrps-yiv-1916151949yiv7021788273yshortcuts {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 .ygrps-yiv-1916151949yiv7021788273green {
color:#628c2a;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 .ygrps-yiv-1916151949yiv7021788273MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 o {
font-size:0;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273photos div {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273photos div div {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273photos div label {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273reco-category {
font-size:77%;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273reco-desc {
font-size:77%;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 .ygrps-yiv-1916151949yiv7021788273replbq {
margin:4px;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-actbar div a:first-child {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-mlmsg {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-mlmsg table {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-mlmsg select, #ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 input, #ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 textarea {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-mlmsg pre, #ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 code {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-mlmsg * {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-mlmsg #ygrps-yiv-1916151949yiv7021788273logo {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-msg p a {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-msg p#ygrps-yiv-1916151949yiv7021788273attach-count span {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-reco #ygrps-yiv-1916151949yiv7021788273reco-head {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-reco {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-sponsor #ygrps-yiv-1916151949yiv7021788273ov li a {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-sponsor #ygrps-yiv-1916151949yiv7021788273ov li {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-sponsor #ygrps-yiv-1916151949yiv7021788273ov ul {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-text {
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1916151949 #ygrps-yiv-1916151949yiv7021788273 #ygrps-yiv-1916151949yiv7021788273ygrp-vital ul li:last-child {
<div id="ygrps-yiv-1368687929yiv6437783194ygrp-text">
<div>
To: yahoogroups
</div>
<div class="ygrps-yiv-1368687929yiv6437783194yqt5387397760" id="ygrps-yiv-1368687929yiv6437783194yqt54669"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-mkp hr {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-mkp #ygrps-yiv-1368687929yiv6437783194hd {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-mkp #ygrps-yiv-1368687929yiv6437783194ads {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-mkp .ygrps-yiv-1368687929yiv6437783194ad {
padding:0 0;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-mkp .ygrps-yiv-1368687929yiv6437783194ad p {
margin:0;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-mkp .ygrps-yiv-1368687929yiv6437783194ad a {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-sponsor #ygrps-yiv-1368687929yiv6437783194ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-sponsor #ygrps-yiv-1368687929yiv6437783194ygrp-lc #ygrps-yiv-1368687929yiv6437783194hd {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-sponsor #ygrps-yiv-1368687929yiv6437783194ygrp-lc .ygrps-yiv-1368687929yiv6437783194ad {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194actions {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194activity {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194activity span {
font-weight:700;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194activity span:first-child {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194activity span a {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194activity span span {
color:#ff7900;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194activity span .ygrps-yiv-1368687929yiv6437783194underline {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 .ygrps-yiv-1368687929yiv6437783194attach {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 .ygrps-yiv-1368687929yiv6437783194attach div a {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 .ygrps-yiv-1368687929yiv6437783194attach img {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 .ygrps-yiv-1368687929yiv6437783194attach label {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 .ygrps-yiv-1368687929yiv6437783194attach label a {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 .ygrps-yiv-1368687929yiv6437783194bold {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 .ygrps-yiv-1368687929yiv6437783194bold a {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 dd.ygrps-yiv-1368687929yiv6437783194last p a {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 dd.ygrps-yiv-1368687929yiv6437783194last p span {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 dd.ygrps-yiv-1368687929yiv6437783194last p span.ygrps-yiv-1368687929yiv6437783194yshortcuts {
margin-right:0;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 div.ygrps-yiv-1368687929yiv6437783194attach-table div div a {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 div.ygrps-yiv-1368687929yiv6437783194attach-table {
width:400px;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 div.ygrps-yiv-1368687929yiv6437783194file-title a, #ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 div.ygrps-yiv-1368687929yiv6437783194file-title a:active, #ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 div.ygrps-yiv-1368687929yiv6437783194file-title a:hover, #ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 div.ygrps-yiv-1368687929yiv6437783194file-title a:visited {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 div.ygrps-yiv-1368687929yiv6437783194photo-title a, #ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 div.ygrps-yiv-1368687929yiv6437783194photo-title a:active, #ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 div.ygrps-yiv-1368687929yiv6437783194photo-title a:hover, #ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 div.ygrps-yiv-1368687929yiv6437783194photo-title a:visited {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 div#ygrps-yiv-1368687929yiv6437783194ygrp-mlmsg #ygrps-yiv-1368687929yiv6437783194ygrp-msg p a span.ygrps-yiv-1368687929yiv6437783194yshortcuts {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 .ygrps-yiv-1368687929yiv6437783194green {
color:#628c2a;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 .ygrps-yiv-1368687929yiv6437783194MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 o {
font-size:0;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194photos div {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194photos div div {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194photos div label {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194reco-category {
font-size:77%;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194reco-desc {
font-size:77%;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 .ygrps-yiv-1368687929yiv6437783194replbq {
margin:4px;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-actbar div a:first-child {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-mlmsg {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-mlmsg table {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-mlmsg select, #ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 input, #ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 textarea {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-mlmsg pre, #ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 code {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-mlmsg * {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-mlmsg #ygrps-yiv-1368687929yiv6437783194logo {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-msg p a {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-msg p#ygrps-yiv-1368687929yiv6437783194attach-count span {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-reco #ygrps-yiv-1368687929yiv6437783194reco-head {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-reco {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-sponsor #ygrps-yiv-1368687929yiv6437783194ov li a {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-sponsor #ygrps-yiv-1368687929yiv6437783194ov li {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-sponsor #ygrps-yiv-1368687929yiv6437783194ov ul {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-text {
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1368687929 #ygrps-yiv-1368687929yiv6437783194 #ygrps-yiv-1368687929yiv6437783194ygrp-vital ul li:last-child {
