I’ve got a client on E9.05.702A SQL, that has created a new SQL database for his training port (9411) named EpicorPIlot905b4. He still has the regular Pilot running on port 9431.
When we restore a copy of LIVE to this TRAIN, it comes up great when we click on the TRAIN icon. Open Edge Explorer also appears to work properly for appserver issues.
However, when I try to run the Admin Tools (I need to run a .r fix file), the Admin Tools tries to run it against the ACTUAL EpicorTrain905 database and not the replacement EpicorPilot905b4 database. I think that because none of the userIDs with system manager privileges are able to login to Admin Tools, the only login accepted is manager/manager.
I’ve looked at the .pf files in the configuration, and they all appear to be set properly. There is an ODBC connection (DNS name: epicortrain905) that is attached to the EpicorPilot905b4 database. Is there some other setting I need to flip to get Admin Tools working on the correct database?
Thanks!
