E10: Tracing a bad BAQ
Thanks Miguel.
It’s odd because in E10, it defaults to BTCustNum.
I working with support now and then are not seeing any difference between OrderHed.CustNum and OrderHed.BTNum.
I’m hoping they come up with something.
Sent: Tuesday, June 23, 2015 12:38 PM
Subject: RE: [Vantage] Re: E10: Tracing a bad BAQ
When I created the query in E9, it naturally linked to Orderhed.CustNum and Customer.CustNum.
I pulled data as well and BTCustNum always was the same value as CustNum. Changing the relationship to BTCUstNum, it did give a slight performance difference (slower). Either way I link it, the same amount of records displayed.
Hope that helps.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Monday, June 22, 2015 1:26 PM
Thanks Jim.
I had called support but haven’t had any luck yet.
I did some testing and the issue appears to be with the join between customer and orderhed.
The BAQ designer will automatically link Customer.CustNum to OrderHed.BTCustNum, which is what I want but this appears to be the problem.
If I toggle it to OrderHed.CustNum, the BAQ runs in less than a second.
Any ideas if there is something I can do on my own to fix this?
[cid:f2fd2d.png@980d6bc4.43b1a29c]
Joe Rojas
Director of Information Technology
(781) 408-9278 Mobile
(781) 573-0291 Local
(781) 232-5191 Fax
[http://matsinc.com/images/e-mail-signatures/tagline.jpg%5d
[http://matsinc.com/images/e-mail-signatures/graphics/logo_matsinc.png%5d<http://matsinc.com> [http://matsinc.com/images/e-mail-signatures/graphics/icon_twitter.png%5d <http://twitter.com/Mats_Inc> [http://matsinc.com/images/e-mail-signatures/graphics/icon_facebook.png%5d <http://www.facebook.com/commercial.flooring> [http://matsinc.com/images/e-mail-signatures/graphics/icon_youtube.png%5d <http://www.youtube.com/user/MatsIncTV> [http://matsinc.com/images/e-mail-signatures/graphics/icon_pinterest.png%5d <http://www.pinterest.com/contractfloors/> [http://matsinc.com/images/e-mail-signatures/graphics/icon_blog.png%5d <http://matsinc.com/blog>
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
Sent: Monday, June 22, 2015 4:24 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
The joins appear to be good and nothing crazy jumps out.
One is a view that has the standard and the UD tables in it so that it looks like a single table, and the other just has the standard orderhed table as you discovered. I have not seen a problem with retrieving things from the view over the standard table so don't have any specific advice. Might do a simple query on just erp/dbo.orderhed and see how the performance is to the view and to the standard table.
If it is way out of whack a call to Epicor may be in order, they may have some tuning/rebuild advice.
Jim Kinneman
Encompass Solutions, Inc.
Hello,
I have a BAQ that takes 2.5 minutes to return 500 rows with information primarily related to sales orders.
This seems a bit extreme giving the speed of other BAQs that we have seen.
I used the SQL Server Profiler (my first time) and can see that it did 114 million reads, which for 500 records seem off.
Where I’m not yet a SQL Server expert, what other SQL tools are there to figure out why there are so many reads?
[cid:3460cd.png@93852a50.47a1be19]
Joe Rojas
(781) 232-5191 Fax
Would you post what tables you are using and how you are joining them?  Might just be an incomplete or bad join.
Jim Kinneman
Here is the SQL from the BAQ.
Interesting to note that when I run this in Management Studio, with a slight change from Erp.OrderHed to dbo.OrderHed, because of the UD fields, it runs under one second.
select
[Customer].[CustID] as [Customer_CustID],
[Customer].[Name] as [Customer_Name],
[OrderHed].[OrderNum] as [OrderHed_OrderNum],
[OrderRel].[OrderLine] as [OrderRel_OrderLine],
[OrderRel].[OrderRelNum] as [OrderRel_OrderRelNum],
[OrderRel].[NeedByDate] as [OrderRel_NeedByDate],
[OrderRel].[ReqDate] as [OrderRel_ReqDate],
[OrderDtl].[PartNum] as [OrderDtl_PartNum],
[OrderDtl].[LineDesc] as [OrderDtl_LineDesc],
[OrderRel].[OurReqQty] as [OrderRel_OurReqQty],
[OrderRel].[IUM] as [OrderRel_IUM],
[OrderRel].[PONum] as [OrderRel_PONum],
[PORel].[POLine] as [PORel_POLine],
[PORel].[PORelNum] as [PORel_PORelNum],
[Vendor].[VendorID] as [Vendor_VendorID],
[Vendor].[Name] as [Vendor_Name],
[OrderHed].[CheckBox03] as [OrderHed_CheckBox03],
[OrderHed].[OrderComment] as [OrderHed_OrderComment],
[OrderDtl].[OrderComment] as [OrderDtl_OrderComment],
[OrderRel].[WarehouseCode] as [OrderRel_WarehouseCode],
[OrderHed].[CheckBox20] as [OrderHed_CheckBox20]
from Erp.Customer as Customer
inner join Erp.OrderHed as OrderHed on
Customer.Company = OrderHed.Company
And
Customer.CustNum = OrderHed.BTCustNum
and ( OrderHed.OpenOrder = 1 and OrderHed.OrderHeld = 0 and (OrderHed.CreditOverride = 1 or OrderHed.CreditOverride = Customer.CreditHold ) )
inner join Erp.OrderDtl as OrderDtl on
OrderHed.Company = OrderDtl.Company
And
OrderHed.OrderNum = OrderDtl.OrderNum
and ( OrderDtl.OpenLine = 1 )
inner join Erp.OrderRel as OrderRel on
OrderDtl.Company = OrderRel.Company
And
OrderDtl.OrderNum = OrderRel.OrderNum
And
OrderDtl.OrderLine = OrderRel.OrderLine
and ( OrderRel.OpenRelease = 1 and OrderRel.BuyToOrder = 1 )
left outer join Erp.PORel as PORel on
OrderRel.Company = PORel.Company
And
OrderRel.PONum = PORel.PONum
And
OrderRel.POLine = PORel.POLine
And
OrderRel.PORelNum = PORel.PORelNum
left outer join Erp.POHeader as POHeader on
PORel.Company = POHeader.Company
And
PORel.PONum = POHeader.PONum
left outer join Erp.Vendor as Vendor on
OrderRel.Company = Vendor.Company
And
OrderRel.VendorNum = Vendor.VendorNum
[cid:d2fd2b.png@de662880.448e4119]
Joe Rojas
(781) 232-5191 Fax
Sent: Monday, June 22, 2015 3:23 PM
Subject: [Vantage] Re: E10: Tracing a bad BAQ
Jim Kinneman
Jim Kinneman
Thanks Jim.
Joe Rojas
(781) 232-5191 Fax
Jim Kinneman
Hope that helps.
Miguel A. Santillan
Thanks Jim.
Joe Rojas
(781) 232-5191 Fax
[http://matsinc.com/images/e-mail-signatures/tagline.jpg]
[http://matsinc.com/images/e-mail-signatures/graphics/logo_matsinc.png]<http://matsinc.com> [http://matsinc.com/images/e-mail-signatures/graphics/icon_twitter.png] <http://twitter.com/Mats_Inc> [http://matsinc.com/images/e-mail-signatures/graphics/icon_facebook.png] <http://www.facebook.com/commercial.flooring> [http://matsinc.com/images/e-mail-signatures/graphics/icon_youtube.png] <http://www.youtube.com/user/MatsIncTV> [http://matsinc.com/images/e-mail-signatures/graphics/icon_pinterest.png] <http://www.pinterest.com/contractfloors/> [http://matsinc.com/images/e-mail-signatures/graphics/icon_blog.png] <http://matsinc.com/blog>
Jim Kinneman
