Is this a custom report you made? or does it happen when you try to print any of the out of the box E10 ssrs reports?
Check on the reporting services configuration manager where your reporting services live. On the configuration manager under Database there’s a place to store credentials for the report server to connect to the report server database.Make sure you have those filled out.
Sent: Wednesday, July 15, 2015 12:03 PM
Subject: [Vantage] E10 SSRS Reporting Error
Hello Everyone
I'm implementing SSRS for my E10 installation and when running a report I receive the following error:
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: One or more data source credentials required to run the report have not been specified. ---> Microsoft.ReportingServices. ReportProcessing. ReportProcessingException: One or more data source credentials required to run the report have not been specified.
at System.Web.Services.Protocols. SoapHttpClientProtocol. ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols. SoapHttpClientProtocol.Invoke( String methodName, Object[] parameters)
I am able to pull the XML without an issue and access SSRS within the browser on the Epicor server; just doesn't generate within Epicor.
Any suggestions?
Thanks!
