I have been juggling E10 databases for a couple months now. Our installation consultant from Epicor kindly did a backup immediately after things were running of the Training DB and I have restored it several times so people can do the embedded education without a prior student’s clutter. That restore is pretty straightforward and only requires check marking “overwriteâ€. Training will remain “pristine†with the Epicor companies to stay in synch with the EE courses.
This morning I set up our Pilot DB as our “gold standard†setup with no transactions by restoring Test to Pilot. Eventually it will be restored to Live (currently empty) and periodically it will be restored back to Test so people can play with increasingly real data. Restoring a backup from one DB to another is a little trickier and took me part of a morning to figure out where to change the destination files part because it takes a long time to populate the files list. Once past that it is pretty easy to do the restores.
I have yet to set up the scheduled backups for Epicor’s databases but had done that previously for MS Dynamics CRM and other SQL Server DBs and it was not a big real.
-Todd C.
Sent: Thursday, October 23, 2014 7:26 AM
Subject: RE: [Vantage] Re: e10 sql backup
Thanks for the responses! I am going from a progress system to SQL and oddly review the documentation for installation and migration I have not found anything on restoring the data base from a backup or even the training data base from a live backup.
Steve
Sent: Wednesday, October 22, 2014 7:19 AM
Subject: [Vantage] Re: e10 sql backup
I took a course on Epicor System management once, and they recommended this script and instructions for setting up a maintenance plan on your SQL database:
SQL Server Backup, Integrity Check, Index and Statistics Maintenance
SQL Server Backup, Integrity Check, Index and Statistics Maintenance SQL Server Backup, Integrity Check, and Index and Statistics Maintenance |
Preview by Yahoo |
