E10 Report Qty - Index 0 is either negative or above rows count
Awesome! Thanks Jose!
Scott
On Wed, Jul 22, 2015 at 2:26 PM, Jose Gomez jose@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><div dir="ltr"><div class="ygrps-yiv-2035061896gmail_default" style="font-family:verdana, sans-serif;font-size:small;"><pre><font color="#1000a0">private</font> <a rel="nofollow" title="System.Void
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://mscorlib:4.0.0.0:b77a5c561934e089/System.Void”>void launchReportQty()
<a rel=“nofollow” title="System.String
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://mscorlib:4.0.0.0:b77a5c561934e089/System.String”>string str = "-1";
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://mscorlib:4.0.0.0:b77a5c561934e089/System.String”>string str2 = "-1";
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://mscorlib:4.0.0.0:b77a5c561934e089/System.String”>string str3 = this.<a rel=“nofollow” title="EpiDataView Erp.Menu.Mes.Transaction.EmpBasicView;
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Erp.Menu.Mes:10.0.700.0:5d3fa3c7105d7992/Erp.Menu.Mes.Transaction/EmpBasicView:Ice.Lib.Framework.EpiDataView”>EmpBasicView.<a rel=“nofollow” title="DataView Ice.Lib.Framework.EpiDataView.dataView { … }
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Ice.Lib.EpiClientLib:3.0.7.0:5d3fa3c7105d7992/Ice.Lib.Framework.EpiDataView/property:dataView:System.Data.DataView”>dataView[0]["CanOverrideJob"].<a rel=“nofollow” title="string System.Object.ToString();
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://mscorlib:4.0.0.0:b77a5c561934e089/System.Object/ToString():String”>ToString();
if (this.<a rel=“nofollow” title="EpiDataView Erp.Menu.Mes.Transaction.LaborDtlView;
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Erp.Menu.Mes:10.0.700.0:5d3fa3c7105d7992/Erp.Menu.Mes.Transaction/LaborDtlView:Ice.Lib.Framework.EpiDataView”>LaborDtlView.<a rel=“nofollow” title="bool Ice.Lib.Framework.EpiDataView.HasRow { … }
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Ice.Lib.EpiClientLib:3.0.7.0:5d3fa3c7105d7992/Ice.Lib.Framework.EpiDataView/property:HasRow:Boolean”>HasRow)
str = this.<a rel=“nofollow” title="EpiDataView Erp.Menu.Mes.Transaction.LaborDtlView;
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Erp.Menu.Mes:10.0.700.0:5d3fa3c7105d7992/Erp.Menu.Mes.Transaction/LaborDtlView:Ice.Lib.Framework.EpiDataView”>LaborDtlView.<a rel=“nofollow” title="DataView Ice.Lib.Framework.EpiDataView.dataView { … }
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Ice.Lib.EpiClientLib:3.0.7.0:5d3fa3c7105d7992/Ice.Lib.Framework.EpiDataView/property:dataView:System.Data.DataView”>dataView[this.<a rel=“nofollow” title="EpiDataView Erp.Menu.Mes.Transaction.LaborDtlView;
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Erp.Menu.Mes:10.0.700.0:5d3fa3c7105d7992/Erp.Menu.Mes.Transaction/LaborDtlView:Ice.Lib.Framework.EpiDataView”>LaborDtlView.<a rel=“nofollow” title="int Ice.Lib.Framework.EpiDataView.Row { … }
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Ice.Lib.EpiClientLib:3.0.7.0:5d3fa3c7105d7992/Ice.Lib.Framework.EpiDataView/property:Row:Int32”>Row]["LaborHedSeq"].<a rel=“nofollow” title="string System.Object.ToString();
str2 = this.<a rel=“nofollow” title="EpiDataView Erp.Menu.Mes.Transaction.LaborDtlView;
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Ice.Lib.EpiClientLib:3.0.7.0:5d3fa3c7105d7992/Ice.Lib.Framework.EpiDataView/property:Row:Int32”>Row]["laborDtlSeq"].<a rel=“nofollow” title="string System.Object.ToString();
<a rel=“nofollow” title="System.Collections.Specialized.StringDictionary
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://System:4.0.0.0:b77a5c561934e089/System.Collections.Specialized.StringDictionary”>StringDictionary dictionary = new <a rel=“nofollow” title="System.Collections.Specialized.StringDictionary.StringDictionary();
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://System:4.0.0.0:b77a5c561934e089/System.Collections.Specialized.StringDictionary/.ctor()”>StringDictionary();
dictionary.<a rel=“nofollow” title="void System.Collections.Specialized.StringDictionary.Add(string, string);
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://System:4.0.0.0:b77a5c561934e089/System.Collections.Specialized.StringDictionary/Add(String,String)”>Add("LaborHead", str);
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://System:4.0.0.0:b77a5c561934e089/System.Collections.Specialized.StringDictionary/Add(String,String)”>Add("LaborDet", str2);
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://System:4.0.0.0:b77a5c561934e089/System.Collections.Specialized.StringDictionary/Add(String,String)”>Add("JobOver", str3);
<a rel=“nofollow” title="Ice.Lib.Framework.LaunchFormOptions
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Ice.Lib.EpiClientLib:3.0.7.0:5d3fa3c7105d7992/Ice.Lib.Framework.LaunchFormOptions”>LaunchFormOptions launchObject = new <a rel=“nofollow” title="Ice.Lib.Framework.LaunchFormOptions.LaunchFormOptions();
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Ice.Lib.EpiClientLib:3.0.7.0:5d3fa3c7105d7992/Ice.Lib.Framework.LaunchFormOptions/.ctor()”>LaunchFormOptions {
<a rel=“nofollow” title="bool Ice.Lib.Framework.LaunchFormOptions.IsModal { … }
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Ice.Lib.EpiClientLib:3.0.7.0:5d3fa3c7105d7992/Ice.Lib.Framework.LaunchFormOptions/property:IsModal:Boolean”>IsModal = false,
<a rel=“nofollow” title="bool Ice.Lib.Framework.LaunchFormOptions.SuppressFormSearch { … }
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Ice.Lib.EpiClientLib:3.0.7.0:5d3fa3c7105d7992/Ice.Lib.Framework.LaunchFormOptions/property:SuppressFormSearch:Boolean”>SuppressFormSearch = true,
<a rel=“nofollow” title="object Ice.Lib.Framework.LaunchFormOptions.ValueIn { … }
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Ice.Lib.EpiClientLib:3.0.7.0:5d3fa3c7105d7992/Ice.Lib.Framework.LaunchFormOptions/property:ValueIn:Object”>ValueIn = dictionary
<a rel=“nofollow” title="Ice.Lib.Framework.ProcessCaller
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Ice.Lib.EpiClientLib:3.0.7.0:5d3fa3c7105d7992/Ice.Lib.Framework.ProcessCaller”>ProcessCaller.<a rel=“nofollow” title="object Ice.Lib.Framework.ProcessCaller.LaunchForm(object, string, object);
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Ice.Lib.EpiClientLib:3.0.7.0:5d3fa3c7105d7992/Ice.Lib.Framework.ProcessCaller/LaunchForm(Object,String,Object):Object”>LaunchForm(this, "Erp.UI.ReportQtyEntry", launchObject);
this.<a rel=“nofollow” title="bool Erp.Menu.Mes.Transaction.RefreshLaborData();
CTRL+Click to open in new tab." target=“_blank” href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Erp.Menu.Mes:10.0.700.0:5d3fa3c7105d7992/Erp.Menu.Mes.Transaction/RefreshLaborData():Boolean”>RefreshLaborData();
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
Quis custodiet
ipsos custodes?
On Wed, Jul 22, 2015 at 2:38 PM, 'Scotty K.' scottyk537@… [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><div dir="ltr">Bump....<span><br><br><p><span>I&#39;m trying to open the Report Qty module in MES from a custom button/event.</span></p><p><span>This is my code:</span></p><p><span>Â Â Â Â Â Â Â  Â Â Â  LaunchFormOptions lfo = new LaunchFormOptions {<br>Â Â Â Â Â Â Â Â Â Â Â  Â Â Â  IsModal = true,<br>Â Â Â Â Â Â Â Â Â Â Â  Â Â Â  SuppressFormSearch = true,<br>Â Â Â  Â Â Â  Â Â Â  Â Â Â  ContextValue = xOpener<br>Â Â Â Â Â Â Â  Â Â Â  };<br>Â Â Â  Â Â Â  Â Â Â  ProcessCaller.LaunchForm(MESMenu,&quot;Erp.UI.ReportQtyEntry&quot;, lfo);</span></p><p><br><span></span></p><p><span>When run I get this error message below.</span></p><p><span>Index 0 is either negative or above rows count.</span></p><p><br></p><p>I suspect I am missing some ValueIn parameters, but can&#39;t seem to find what is needed.<br><span></span></p><p><span>Can anyone help?</span></p><p><br><span></span></p><span>Scott</span><br></span></div><span><div class="ygrps-yiv-2035061896gmail_extra"><br><div class="ygrps-yiv-2035061896gmail_quote">On Tue, Jul 21, 2015 at 10:15 AM, <a rel="nofollow" target="_blank" href="mailto:scottyk537@...">scottyk537@...</a> [vantage] <span dir="ltr">&lt;<a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a>&gt;</span> wrote:<br><blockquote class="ygrps-yiv-2035061896gmail_quote" style="border-left:1px #ccc solid;">
Â
<div>
  <p></p><p><span>I&#39;m trying to open the Report Qty module in MES from a custom button/event.</span></p><p><span>This is my code:</span></p><p><span>Â Â Â Â Â Â Â  Â Â Â  LaunchFormOptions lfo = new LaunchFormOptions {<br>Â Â Â Â Â Â Â Â Â Â Â  Â Â Â  IsModal = true,<br>Â Â Â Â Â Â Â Â Â Â Â  Â Â Â  SuppressFormSearch = true,<br>Â Â Â  Â Â Â  Â Â Â  Â Â Â  ContextValue = xOpener<br>Â Â Â Â Â Â Â  Â Â Â  };<br>Â Â Â  Â Â Â  Â Â Â  ProcessCaller.LaunchForm(MESMenu,&quot;Erp.UI.ReportQtyEntry&quot;, lfo);</span></p><p><br><span></span></p><p><span>When run I get this error message below.</span></p><p><span>Index 0 is either negative or above rows count.</span></p><p><br></p><p>I suspect I am missing some ValueIn parameters, but can&#39;t seem to find what is needed.<br><span></span></p><p><span>Can anyone help?</span></p><p><br><span></span></p><p><span>Scott<br></span></p><p><span><br></span></p><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
</div>
</div>
I'm trying to open the Report Qty module in MES from a custom button/event.
This is my code:
                IsModal = true,
            ProcessCaller.LaunchForm(MESMenu,"Erp.UI.ReportQtyEntry", lfo);
I suspect I am missing some ValueIn parameters, but can't seem to find what is needed.
Can anyone help?
Scott
Bump....
This is my code:
              IsModal = true,
Can anyone help?
Scott
On Tue, Jul 21, 2015 at 10:15 AM, scottyk537@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
</div>
private http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://mscorlib:4.0.0.0:b77a5c561934e089/System.Void”>void launchReportQty()
Jose C Gomez
Software Engineer
Quis custodiet
ipsos custodes?
Â
<div>
  <p></p><div dir="ltr">Bump....<span class="ygrps-yiv-1398988137"><br><br><p><span>I&#39;m trying to open the Report Qty module in MES from a custom button/event.</span></p><p><span>This is my code:</span></p><p><span>Â Â Â Â Â Â Â  Â Â Â  LaunchFormOptions lfo = new LaunchFormOptions {<br>Â Â Â Â Â Â Â Â Â Â Â  Â Â Â  IsModal = true,<br>Â Â Â Â Â Â Â Â Â Â Â  Â Â Â  SuppressFormSearch = true,<br>Â Â Â  Â Â Â  Â Â Â  Â Â Â  ContextValue = xOpener<br>Â Â Â Â Â Â Â  Â Â Â  };<br>Â Â Â  Â Â Â  Â Â Â  ProcessCaller.LaunchForm(MESMenu,&quot;Erp.UI.ReportQtyEntry&quot;, lfo);</span></p><p><br><span></span></p><p><span>When run I get this error message below.</span></p><p><span>Index 0 is either negative or above rows count.</span></p><p><br></p><p>I suspect I am missing some ValueIn parameters, but can&#39;t seem to find what is needed.<br><span></span></p><p><span>Can anyone help?</span></p><p><br><span></span></p><span>Scott</span><br></span></div><span class="ygrps-yiv-1398988137"><div class="ygrps-yiv-1398988137gmail_extra"><br><div class="ygrps-yiv-1398988137gmail_quote">On Tue, Jul 21, 2015 at 10:15 AM, <a rel="nofollow" target="_blank" href="mailto:scottyk537@...">scottyk537@...</a> [vantage] <span dir="ltr">&lt;<a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a>&gt;</span> wrote:<br><blockquote class="ygrps-yiv-1398988137gmail_quote" style="border-left:1px #ccc solid;">
Â
<div>
</div>
</div>
