E10 - Received Not Invoiced Report
In E10 now, after you run the Capture process, the Received Not Invoiced Report is now supposed to show the GL Expense account associated with the PO. Problem is that its showing the Credit Side (AP Clearing or AP Account, depending on your setup) instead of the more meaningful debit side. Support said they are looking at it
Anyone else running this and seeing the correct Debit GL Account?
