Thanks Jose. I had read the tech guide but for some I interpreted it to mean that On Field Changed was server side.
It was the part about “…while it is in focus and saved during an actual configuration session.â€. The word “saved†sounded like a database save, which I assumed would be server side.
I will test further.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
addr: 179 Campanelli Pkwy | Stoughton | MA | 02072-3734
jrojas@... | www.matsinc.com
Ask us about our clean, green and beautiful matting and flooring
[cid:a949c1.png@e3286a32.41a9b6b9]
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Sent: Thursday, March 19, 2015 10:39 AM
To: Vantage
Subject: Re: [Vantage] E10: Product Configurator - Setting input values on Field Validating
Not sure about configurator per-say but standard behavior is is as follows]
Validating occurs when you (exit/leave) a field ,whether its changed or not
OnFieldChanged occurs when the field changes
Both of these are client side calls, though the execution may require the server to give you some data.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
[Image removed by sender.]<http://www.linkedin.com/in/josecgomez> [Image removed by sender.] <http://www.facebook.com/josegomez> [Image removed by sender.] <http://www.google.com/profiles/jose.gomez> [Image removed by sender.] <http://www.twitter.com/joc85> [Image removed by sender.] <http://www.josecgomez.com/professional-resume/> [Image removed by sender.] <http://www.josecgomez.com/feed/>
To: Vantage
Jose C Gomez
Software Engineer
On Thu, Mar 19, 2015 at 10:30 AM, Joe Rojas jrojas@...<mailto:jrojas@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
Hello,
My understanding is that an inputs “On Field Validating†action is fired when the field changes and is run on the client side and the “On Field Changed†action is fired when the field changes and is run on the server side.
My hope was that I could change the value of another input then the user selects a value from a combo box and have this run on the client side so that it can happen faster than waiting for the server to process the request.
When I tried this, I got an error that said I cannot update an input value on Field Validating and must happen on Field Changed.
This is kind of a bummer but I just want to make sure I understand correctly.
dir: 781-573-0291<tel:781-573-0291> | cell: 781-408-9278<tel:781-408-9278> | fax: 781-232-5191<tel:781-232-5191>
jrojas@...<mailto:jrojas@...> | www.matsinc.com<http://www.matsinc.com>
[cid:56da57.png@f018312d.4db269fd]
