E10 new implementation
The client side has not changed that much from E9 to 10…The biggest change is on the server side.
Sent: Thursday, December 4, 2014 9:42 AM
Subject: RE: [Vantage] E10 new implementation
That’s a great approach to go the re-implementation route.  Things change over time (even just 7 years) and this is a golden opportunity to re-align the system to the company.  Also to get rid of obsolete data (data cleansing they call it).  If you don’t have DMT get  it – it is a great (if slightly flawed in spots) tool for importing cleaned up data for the Master files.  Only quirk I’ve seen is it will tell you what the required fields are and then choke on fields it did not tell you about.  If you do a DMT install and orientation session with Epicor be sure to ask for the Data Migration Map – a spreadsheet that shows the order files need to be imported – sort of a precedence ranking.  I have one table remaining to populate – Customers (and related sub-tables like contacts).
I agree on some of the frustration with the methodology.  We go back to DCD-Classic and there are some who remember the migration to Vantage 5.0 (for me it was Classic to Vantage 4.0 at another company, so 15 years with it) – so we know the system in general.  Then again about half the people have been here less than 2 years and never saw  Vantage so the rest of us are coaching them.   Even with the methodology we had a lot of people yesterday get blown away by grouping, filtering and summaries in grid views – aside from Embedded Education there was no specific place to point out that feature.
-Todd C.
Sent: Thursday, December 04, 2014 7:58 AM
Subject: Re: [Vantage] E10 new implementation
Thanks to all for all the input.
We're live on E905702a and doing a re-implementation to E10, bringing most of the (scrubbed) master data but no transactions.  Reimplementation is to fix some big flaws and major gaps in process that have existed since initial implementation.
We're very early in the process and not up to dealing with the reports and backups yet.  Just trying to get through the gauntlet of 'Epicor Signature Methodology' in which they assume we are complete newbies and treat us as such even though I've told them a buzillion times that we've been running the product 7 years since implementing 8.03.
Reports: I presume that we will push through to new SSRS versions of the ~12-20 most used reports initially, but start the others as Crystal with conversion as rapidly after GO LIVE as can be accommodated.
Physical vs. Virtual: Our whole datacenter including the various Epicor (9 & 10) servers are all VMware.  I would say we've seen some occasional weakness in performance.  In VM bumping up resources is easy, tuning the appservers is more difficult because VM intrinsically shifts resources to meet various guest server demands.  The advice I would give is to keep the ERP servers on specific hardware exclusive to ERP, and minimize or avoid over-booking the resources.
James
On Wednesday, December 3, 2014 7:28 PM, "Henry_Yahoo henry_czyz@... [vantage]" <vantage@yahoogroups.com> wrote:
On 12/3/2014 3:47 PM, Todd Caughey tcaughey@... [vantage] wrote:
New E10  site here too.  Seriously planning on starting out with Crystal – just for speed of development against an end of January go-live.  I can do in a couple hours what will take me 3-4 days in SSRS at this point on the learning curve.  Over time as learning takes place we will gradually switch to SSRS.  I’m not worried about performance with Crystal because most issues are links and filter related and I know what to watch out for.
But the whole issue reminds me of the transition between Progress 9.1 and10 when Report Builder went away and everyone had to switch to Crystal Reports.   We don’t want to get into the position where Epicor drops the ability to select either type and still run within the system rather than externally.   One big reason my former employer dropped support & maintenance was due to deciding not to migrate from Vantage 6.1 and the biggest reason for that was 500+ RB reports and the time required to convert to Crystal.  Here and now we don’t want to get backed in to that corner so Crystal will probably be a temporary (year or so) expediency with the intention to do more SSRS over time.  But I do like Crystal a lot better.
-Todd C.
Sent: Wednesday, December 03, 2014 3:04 PM
Subject: [Vantage] E10 new implementation
Hi,
We are implementing E10 and moving over from our old ERP solution.
What are you guys using for reporting in E10 ? SSRS or stay with CR. I tested SSRS a little bit but I was working with CR before and looks like is working better for me.
Any speed issues with SSRS. We have brand new equipment and some reports are oping fast some of them like invoice we have to wait 15 sec to open.
thanks
henry
Thank you for input. I heard that Epicor will drop off CR and stay with SSRS only. We are planning to go live August next year. During setup we recognized few issues connected to scheduling and financing. Looks like that is global issue, basically was working in 9, not working in 10. What release you are on ? We are on 702, I saw Epicor released already 703 but I did not see major improvements.   Also how your backup and restore is working. I can say some king of headache. Epicor's procedure is not working like suppose to be. Stop pool from epicor admin is not enough to stop/kill database. Even go off with database direct from SQL studio is taking a lot of time. I'm running simple query to switch database in single mode and kill connections. We are on SQL 2012. I'm just curious what issues in front of me :) Are you on virtual servers or regular machine  ?
thanks
h.
Hi,
thanks
henry
-Todd C.
Hi,
thanks
henry
I would recommend SSRS it is the platform that Epicor Recommends and they are not likely to go back to Crystal, I suspect in soon releases they may drop support for Crystal All together.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Wed, Dec 3, 2014 at 4:47 PM, Todd Caughey tcaughey@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>
Â
Â
-Todd C.
Â
Â
Â
Â
Hi,
thanks
henry
Â
</div>
<div style="color:#fff;min-height:0;"></div>
<div class="ygrps-yiv-1858814953moz-cite-prefix">On 12/3/2014 3:47 PM, Todd Caughey
  <a rel="nofollow" class="ygrps-yiv-1858814953moz-txt-link-abbreviated" target="_blank" href="mailto:tcaughey@...">tcaughey@...</a> [vantage] wrote:<br>
</div>
<blockquote><span title="qreply"> <blockquote
type=“cite”> Â
      <div id="ygrps-yiv-1858814953ygrp-text">
        <p>
        </p>
        <div class="ygrps-yiv-1858814953WordSection1">
          <p class="ygrps-yiv-1858814953MsoNormal"><span
style=“font-size:11.0pt;color:#1F497D;”>New
Â
But
system rather than externally. Â Â One big reason my
Â
-Todd
C.
Â
Â
Â
Â
Hi,
old ERP solution.
thanks
henry
Â
</blockquote>
Epicor released already 703 but I did not see major improvements. Â
headache. Epicor&#39;s procedure is not working like suppose to be. Stop
I&#39;m running simple query to switch database in single mode and kill
connections. We are on SQL 2012. I&#39;m just curious what issues in
front of me :) Are you on virtual servers or regular machine  ? <br>
thanks <br>
<br>
h.<br>
<br>
James
<div id="ygrps-yiv-174820117yiv0240190283ygrp-text">
  <div>
</div><div class="ygrps-yiv-174820117yiv0240190283yqt5822659918" id="ygrps-yiv-174820117yiv0240190283yqt50372"><div class="ygrps-yiv-174820117yiv0240190283moz-cite-prefix">On 12/3/2014 3:47 PM, Todd Caughey
  <a rel="nofollow" class="ygrps-yiv-174820117yiv0240190283moz-txt-link-abbreviated" target="_blank" href="mailto:tcaughey@..." shape="rect">tcaughey@...</a> [vantage] wrote:<br clear="none">
</div>
<blockquote><span title="qreply"> <blockquote type="cite"> <span>&nbsp;</span>
        <div>
        </div>
        <div class="ygrps-yiv-174820117yiv0240190283WordSection1">
          <div class="ygrps-yiv-174820117yiv0240190283MsoNormal"><span style="font-size:11pt;">New
              E10&nbsp; site here too.&nbsp; Seriously planning on starting
              against an end of January go-live.&nbsp; I can do in a
              this point on the learning curve.&nbsp; Over time as
              SSRS.&nbsp; I’m not worried about performance with Crystal
              know what to watch out for.</span></div>
          <div class="ygrps-yiv-174820117yiv0240190283MsoNormal"><span style="font-size:11pt;"> &nbsp;</span></div>
          <div class="ygrps-yiv-174820117yiv0240190283MsoNormal"><span style="font-size:11pt;">But
              everyone had to switch to Crystal Reports.&nbsp;&nbsp; We don’t
              system rather than externally. &nbsp;&nbsp;One big reason my
              former employer dropped support &amp; maintenance was
              the time required to convert to Crystal.&nbsp; Here and now
              time.&nbsp; But I do like Crystal a lot better.</span></div>
          <div class="ygrps-yiv-174820117yiv0240190283MsoNormal"><span style="font-size:11pt;">-Todd
              C.</span></div>
          <div>
            <div style="padding:3pt 0in 0in;border-top-color:rgb(225, 225, 225);border-top-width:1pt;border-top-style:solid;">
              <div class="ygrps-yiv-174820117yiv0240190283MsoNormal"><b><span style="font-size:11pt;">From:</span></b><span style="font-size:11pt;">
                  <a rel="nofollow" class="ygrps-yiv-174820117yiv0240190283moz-txt-link-abbreviated" target="_blank" href="mailto:vantage@yahoogroups.com" shape="rect">vantage@yahoogroups.com</a>
                  [<a rel="nofollow" class="ygrps-yiv-174820117yiv0240190283moz-txt-link-freetext" target="_blank" href="mailto:vantage@yahoogroups.com" shape="rect">mailto:vantage@yahoogroups.com</a>]
                  <br clear="none">
                  <b>Sent:</b> Wednesday, December 03, 2014 3:04 PM<br clear="none">
                  <b>To:</b> <a rel="nofollow" class="ygrps-yiv-174820117yiv0240190283moz-txt-link-abbreviated" target="_blank" href="mailto:vantage@yahoogroups.com" shape="rect">vantage@yahoogroups.com</a><br clear="none">
                  <b>Subject:</b> [Vantage] E10 new implementation</span></div>
            </div>
          </div>
          <div class="ygrps-yiv-174820117yiv0240190283MsoNormal"> &nbsp;</div>
          <div class="ygrps-yiv-174820117yiv0240190283MsoNormal">&nbsp; </div>
          <div id="ygrps-yiv-174820117yiv0240190283ygrp-mlmsg">
            <div id="ygrps-yiv-174820117yiv0240190283ygrp-msg">
                <div>Hi, <br clear="none">
                  <br clear="none">
                  old ERP solution. <br clear="none">
                  <br clear="none">
                  <br clear="none">
                  <br clear="none">
                  thanks<br clear="none">
                  <br clear="none">
                  henry</div>
                <div> &nbsp;</div>
              </div>
              <div>
                <div class="ygrps-yiv-174820117yiv0240190283MsoNormal"><span style="color:white;"></span></div>
              </div>
            </div>
          </div>
        </div>
      </div>
</blockquote></span></blockquote></div>
Epicor released already 703 but I did not see major improvements. &nbsp;
front of me :) Are you on virtual servers or regular machine&nbsp; ? <br clear="none">
thanks <br clear="none">
<br clear="none">
h.<br clear="none">
<br clear="none">
</div>
<div class="ygrps-yiv-174820117yiv0240190283yqt5822659918" id="ygrps-yiv-174820117yiv0240190283yqt13635"><div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283 -- #ygrps-yiv-174820117yiv0240190283ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-mkp #ygrps-yiv-174820117yiv0240190283hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-mkp #ygrps-yiv-174820117yiv0240190283ads {
margin-bottom:10px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-mkp .ygrps-yiv-174820117yiv0240190283ad {
padding:0 0;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-mkp .ygrps-yiv-174820117yiv0240190283ad p {
margin:0;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-mkp .ygrps-yiv-174820117yiv0240190283ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-sponsor #ygrps-yiv-174820117yiv0240190283ygrp-lc {
font-family:Arial;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-sponsor #ygrps-yiv-174820117yiv0240190283ygrp-lc #ygrps-yiv-174820117yiv0240190283hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-sponsor #ygrps-yiv-174820117yiv0240190283ygrp-lc .ygrps-yiv-174820117yiv0240190283ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283activity span {
font-weight:700;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283activity span span {
color:#ff7900;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283activity span .ygrps-yiv-174820117yiv0240190283underline {
text-decoration:underline;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 .ygrps-yiv-174820117yiv0240190283attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 .ygrps-yiv-174820117yiv0240190283attach div a {
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 .ygrps-yiv-174820117yiv0240190283attach img {
border:none;padding-right:5px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 .ygrps-yiv-174820117yiv0240190283attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 .ygrps-yiv-174820117yiv0240190283attach label a {
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 .ygrps-yiv-174820117yiv0240190283bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 .ygrps-yiv-174820117yiv0240190283bold a {
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 dd.ygrps-yiv-174820117yiv0240190283last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 dd.ygrps-yiv-174820117yiv0240190283last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 dd.ygrps-yiv-174820117yiv0240190283last p span.ygrps-yiv-174820117yiv0240190283yshortcuts {
margin-right:0;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 div.ygrps-yiv-174820117yiv0240190283attach-table div div a {
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 div.ygrps-yiv-174820117yiv0240190283attach-table {
width:400px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 div.ygrps-yiv-174820117yiv0240190283file-title a, #ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 div.ygrps-yiv-174820117yiv0240190283file-title a:active, #ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 div.ygrps-yiv-174820117yiv0240190283file-title a:hover, #ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 div.ygrps-yiv-174820117yiv0240190283file-title a:visited {
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 div.ygrps-yiv-174820117yiv0240190283photo-title a, #ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 div.ygrps-yiv-174820117yiv0240190283photo-title a:active, #ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 div.ygrps-yiv-174820117yiv0240190283photo-title a:hover, #ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 div.ygrps-yiv-174820117yiv0240190283photo-title a:visited {
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 div#ygrps-yiv-174820117yiv0240190283ygrp-mlmsg #ygrps-yiv-174820117yiv0240190283ygrp-msg p a span.ygrps-yiv-174820117yiv0240190283yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 .ygrps-yiv-174820117yiv0240190283green {
color:#628c2a;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 .ygrps-yiv-174820117yiv0240190283MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 o {
font-size:0;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283photos div {
float:left;width:72px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283reco-category {
font-size:77%;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283reco-desc {
font-size:77%;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 .ygrps-yiv-174820117yiv0240190283replbq {
margin:4px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-mlmsg select, #ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 input, #ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-mlmsg pre, #ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 code {
font:115% monospace;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-mlmsg #ygrps-yiv-174820117yiv0240190283logo {
padding-bottom:10px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-msg p#ygrps-yiv-174820117yiv0240190283attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-reco #ygrps-yiv-174820117yiv0240190283reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-sponsor #ygrps-yiv-174820117yiv0240190283ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-sponsor #ygrps-yiv-174820117yiv0240190283ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-sponsor #ygrps-yiv-174820117yiv0240190283ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-text {
font-family:Georgia;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-text tt {
font-size:120%;}
#ygrps-yiv-174820117 #ygrps-yiv-174820117yiv0240190283 #ygrps-yiv-174820117yiv0240190283ygrp-vital ul li:last-child {
border-right:none !important;}
-Todd C.
James
-Todd C.
Hi,
thanks
henry
thanks
h.
