So I created a customization on Quote Entry. I added a child table through the Wizard to conenct UD01 to QuoteDtl. Everything is good so far, except that when I asked someone to test my customization, they now can not add lines. It is greyed out. They can add a Header, but no lines.
When I removed the customization from that menu item, they can add lines again.
I am attaching the customization, in case you want to take a peek at it. I can not see how I am impacting the option to add a line. Except that I changed a few lines in the manufactured method “InitializeUD01Adapter”.
I know. There are a few lines of code that the system created that I changed. I had the controls of my tab binded to the UD01View, But I think because I didn’t display any objects that were binded to Key1 or Key2, that things did not work in the normal sense. So I removed/disabled the display of the Add Text for UD01 and disassociated the UD01View from the controls. I added an “Add” button to handle the functionality.
That is one of the changes that I could see (but not understand) that would impact the QuoteDtl New behavior in the dropdown of the “New” icon. The problem is in the “New” icon. The QuoteDtl or Quote Line New does not enable for OTHER people. It is enabled for me though.
Ok, so I think I figured out what happened. The user that could not get “New Quote Line” to enable had a Personalization on the customization. I deleted it and then the user could do everything. I think they added the personalization before I disabled the “New UD01” option, which then changed the “NEW” list.
