How are others handling SSL certs for self hosted Epicor instances?
We’re using a self signed cert, but this is causing problems with javascript(executed in browser) Epicor REST requests… I don’t personally like the idea of manually accepting the cert on all browsers on all PCs… Curios how others are addressing this issue.
To answer your question, yes. You purchase certificates for hosts not IPs. Doesn’t matter if the IP for that host is a public or private IP. The cert is the same.
That really depends on where you buy your certs and what type you’re buying. Some common CAs are Sectigo and DigiCert. Look at their Wildcard SSL pricing and just DV pricing. Both list pricing on their site.
If you have a Active Directory Domain you can easily setup an internal CA that all your workstations respect and acknowledge and then you can make as many certs as you want for free
Another thought. You could keep using self-signed certs. And use a GPO to add them to all PCs as a trusted cert. If you don’t want to purchase CA certs.
We’re very Unix centric and don’t have much in the way of Windows server infrastructure… It’s great to know we can purchase certs for private servers, I always thought that wasn’t an option
Sorry, didn’t mean to quote Sectigo… I meant for the approach with Active Directory and Group Policies, we don’t have the infrastructure, so it looks like buying a cert is the solution we were looking for!
