<div id="ygrps-yiv-905219887ygrp-text"> <p>Hello,
I believe I have everything setup for E10 to print SSRS reports.
I attempted to do a print preview of the base Order Acknowledgement report but got this error in the System Monitor.
Any idea?
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: System.Web.Services.Protocols.SoapException: The Hidden expression for the tablix ‘Table1’ contains an error: Input string was not in a correct format. ---> Microsoft.ReportingServices.Diagnostics.Utilities.RSException: The Hidden expression for the tablix ‘Table1’ contains an error: Input string was not in a correct format.
at Microsoft.ReportingServices.Library.ReportExecution2005Impl.InternalRender(String Format, String DeviceInfo, PageCountMode pageCountMode, Stream& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
at Microsoft.ReportingServices.Library.ReportExecution2005Impl.Render(String Format, String DeviceInfo, PageCountMode pageCountMode, Byte[]& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
at Microsoft.ReportingServices.WebServer.ReportExecutionService.Render(String Format, String DeviceInfo, Byte[]& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Ice.Core.SsrsReportService.ReportExecutionService.Render(String Format, String DeviceInfo, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
at Ice.Core.SsrsReporting.SsrsReportRenderer.Render(SsrsRenderInformationBase renderInformation)
at Ice.Core.SsrsReporting.ReportProcessorBase`1.RenderReportForPreviewOrClientPrint(SysRptLst sysRptLstRow)
at Ice.Core.SsrsReporting.ReportProcessorBase`1.ProcessReportPart(String reportLocation, Action`1 modifySysRptLstRow)
at Ice.Core.RptBase.ReportDatabaseBuilder`1.XMLClose()
at Erp.Internal.OM.SalesOrderAck.RunProcess(Int32 instanceTaskNum, String outputFileName)
at Ice.Hosting.TaskCaller.ExecuteTask()
at Ice.Services.Lib.RunTaskSvc.RunTask(Int32 ipTaskNum)
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
addr: 179 Campanelli Pkwy | Stoughton | MA | 02072-3734
jrojas@... | www.matsinc.com
Ask us about our clean, green and beautiful matting and flooring
[cid:20b2b1.png@b8ad4a66.4ea05476]
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
</div> <div style="color:#fff;height:0;"></div>
Any idea?
Jose C Gomez
T: 904.469.1524 mobile
On Fri, Apr 24, 2015 at 11:45 AM, Joe Rojas jrojas@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>Hello,
Any idea?
</div> <div style="color:#fff;min-height:0;"></div>
This is the base Epicor report so I wouldn’t expect there to be an issue with the report itself but I can take a look if that’s what you mean.
[cid:7158d3.png@01dd6ffc.4f8ba2cc]
Sent: Friday, April 24, 2015 11:49 AM
To: Vantage
Subject: Re: [Vantage] E10: First attempt to print SSRS report - error
YOu have a problem in your SSRS Hideen Expression for Table 1. Look in SSRS Table.Visibility and see what it says?
Jose C Gomez
Software Engineer
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
[Image removed by sender.]<http://www.linkedin.com/in/josecgomez> [Image removed by sender.] <http://www.facebook.com/josegomez> [Image removed by sender.] <http://www.google.com/profiles/jose.gomez> [Image removed by sender.] <http://www.twitter.com/joc85> [Image removed by sender.] <http://www.josecgomez.com/professional-resume/> [Image removed by sender.] <http://www.josecgomez.com/feed/>
On Fri, Apr 24, 2015 at 11:45 AM, Joe Rojas jrojas@...<mailto:jrojas@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
Hello,
Any idea?
dir: 781-573-0291<tel:781-573-0291> | cell: 781-408-9278<tel:781-408-9278> | fax: 781-232-5191<tel:781-232-5191>
jrojas@...<mailto:jrojas@...> | www.matsinc.com<http://www.matsinc.com>
Jose C Gomez
On Fri, Apr 24, 2015 at 12:00 PM, Joe Rojas jrojas@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>Do you mean open this report in SSRS to troubleshoot?
To: Vantage
Jose C Gomez
Software Engineer
Hello,
Any idea?
</div><span class="ygrps-yiv-1668077174"> <div style="color:#fff;min-height:0;"></div>
Jose C Gomez
On Fri, Apr 24, 2015 at 12:12 PM, Jose Gomez <jose@...> wrote:Odd, the error it is throwing appears to be within the SSRS Report itself... specifically the main Tablix1....
Jose C GomezSoftware Engineer
T: 904.469.1524 mobileE: jose@...
http://www.josecgomez.comÂ
Â
Â
Â
Â
Â
Quis custodiet ipsos custodes?On Fri, Apr 24, 2015 at 12:00 PM, Joe Rojas jrojas@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>Do you mean open this report in SSRS to troubleshoot?
To: Vantage
Jose C Gomez
Software Engineer
Hello,
Any idea?
</div><span> <div style="color:#fff;min-height:0;"></div>
I was able to print the base version of a Purchase Order with no problem.
I was wondering, is there a way to reload the SSRS reports?
[cid:e21022.png@2df2df47.4f9e30a5]
Sent: Friday, April 24, 2015 12:12 PM
To: Vantage
Can you print other reports?
Jose C Gomez
Software Engineer
On Fri, Apr 24, 2015 at 12:12 PM, Jose Gomez <jose@...<mailto:jose@...>> wrote:
Jose C Gomez
Software Engineer
T: 904.469.1524<tel:904.469.1524> mobile
On Fri, Apr 24, 2015 at 12:00 PM, Joe Rojas jrojas@...<mailto:jrojas@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>]
To: Vantage
Jose C Gomez
Software Engineer
E: jose@...<mailto:jose@...><mailto:jose@...<mailto:jose@...>>
On Fri, Apr 24, 2015 at 11:45 AM, Joe Rojas jrojas@...<mailto:jrojas@...><mailto:jrojas@...<mailto:jrojas@...>> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>> wrote:
Hello,
Any idea?
dir: 781-573-0291<tel:781-573-0291><tel:781-573-0291<tel:781-573-0291>> | cell: 781-408-9278<tel:781-408-9278><tel:781-408-9278<tel:781-408-9278>> | fax: 781-232-5191<tel:781-232-5191><tel:781-232-5191<tel:781-232-5191>>
jrojas@...<mailto:jrojas@...><mailto:jrojas@...<mailto:jrojas@...>> | www.matsinc.com<http://www.matsinc.com><http://www.matsinc.com>
From: "Joe Rojas jrojas@... [vantage]" <vantage@yahoogroups.com>
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Friday, April 24, 2015 11:45 AM
Subject: [Vantage] E10: First attempt to print SSRS report - error
Hello,
Any idea?
Posted by: Joe Rojas <jrojas@...>
Yahoo Groups Links
<*> To visit your group on the web, go to:
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
http://groups.yahoo.com/group/vantage/join
(Yahoo! ID required)
<*> To change settings via email:
vantage-digest@yahoogroups.com
vantage-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo Groups is subject to:
https://info.yahoo.com/legal/us/yahoo/utos/terms/
