Hi,
I’m wanting to customize the UD26 maintenance, where a new row is opened on form load and default fields are set. I don’t want the user to have to enter Key1 and Key2.
I have this code:
private void UD26Form_Load(object sender, EventArgs args)
// Add Event Handler Code
string userID = ((Ice.Core.Session)oTrans.Session).UserID;
string companyID = ((Ice.Core.Session)oTrans.Session).CompanyID;
EpiDataView edvUD26 = ((EpiDataView)(oTrans.EpiDataViews["UD26"]));
// ----- error on next statement -----
edvUD26.dataView.Table.Rows.Add(); // tried 0 and 1 here, too
edvUD26.dataView[0]["Company"] = companyID;
edvUD26.dataView[0]["Key1"] = "PickListLabel";
edvUD26.dataView[0]["Key2"] = userID;
edvUD26.Notify( new EpiNotifyArgs(oTrans, edvUD26.Row, edvUD26.Column) );
It compiles okay, but on the statement noted above gets the following error when I open UD26 maintenance:
Message: Exception has been thrown by the target of an invocation.
Inner Exception Message: Specified cast is not valid.
(Complete error description below.)
Point me in the right direction?
Joe Trent
Application Error
Exception caught in: mscorlib
Error Detail
Program: CommonLanguageRuntimeLibrary
Method: InvokeMethod
Client Stack Trace
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Ice.Lib.Customization.CustomScriptMethodInvoker.InvokeScriptMethod(MethodInfo scriptMethod, Object[] parameters)
at Ice.Lib.Customization.CustomScriptMethodInvoker.InvokeCustomFormLoadIfExists(String methodName, Object sender, EventArgs e)
at Ice.Lib.Customization.CustomScriptManager.<>c__DisplayClass103_0.b__0()
at Ice.Lib.Customization.CustomScriptManager.TryActionShowExceptionBoxOrLogVerificationErrorIfException(Action action, String exceptionBoxTitle)
Inner Exception
at Ice.Lib.Framework.EpiTreeView.treeLoader(EpiTreeNode parentNode, EpiDataView treeView, EpiTreeBinding treeBinding, String filter)
at Ice.Lib.Framework.EpiTreeView.ResetTreeData(Boolean preserveNodeState)
at Ice.Lib.Framework.EpiTreeView.onNotification(EpiDataView view, EpiNotifyArgs ar, Boolean visibilityChanged)
at Ice.Lib.Framework.EpiTreeView.oDataView_EpiNotification(EpiDataView view, EpiNotifyArgs ar)
at Ice.Lib.Framework.EpiViewNotification.Invoke(EpiDataView view, EpiNotifyArgs args)
at Ice.Lib.Framework.EpiDataView.OnEpiViewNotification(EpiNotifyArgs e)
at Ice.Lib.Framework.EpiDataView.Notify(EpiNotifyArgs args)
at Script.UD26Form_Load(Object sender, EventArgs args)
