E10 custom to EWA
Hi All.
I have a custom in the APInvoice form which is currently running properly in 10.0.700.4. I was written in C#.
during the upgrade process it seems to be “converted properly” and it is running smoothly in the local client.
when came into the customization maintenance and Generate the Web form for that specific custom, a file with the custom name is generated but custom code is not there, is there anything else required before generating the web forms?
I assume you found the file you referenced in your EWA root folder and it was the ASP .Net Server Page? If you search by date are there are additional files in the sub-folder (i.e. scripts)? Have you been able to generate any other customizations or perhaps a test customization? I would also run a verify against the customization just to make sure that is successful.
Hi Dan, thank you for your response. it is indeed the root folder but there aren´t any additional files generated. I will give it a try with a tiny test custom to see how it is deployed.
