In a Cloud setting, Menu Mtc has customization option grayed for default system Menu Items ie… Order Entry. I can add a new custom Menu item using the Order Entry dll , select and apply the customization. I need to apply the customization to the default Order Entry so that when a Open With action is taken, the customization will be applied to the action. Thanks.
You need to make use of Process Calling Maintenance to point all times Order Entry is called to your new menu.
