E10 Bartender Shipping Labels
What I’ve done is to select the ShipHead table in the RDD.  Then, I select the Linked Tables sheet, then on the Pick Links available I moved Customer, ShipToCust and ShipViaCode to the Picked column.  On the Pick Fields for this Link “ShipToCust” I’ve picked all the address fields.  Is this not the correct way this should be done?
Also, I did confirm that the ShipToNum is available in the output data.
Thanks!
Sent: Wednesday, December 16, 2015 11:03 AM
Subject: [Vantage] RE: E10 Bartender Shipping Labels
Are you are linking to the Ship-To table using the ship-to number for the desired ship to?  Linking without it will select the Bill-to which is stored in the Ship-to table but with a blank ship-to number.  Likewise check the order’s Header form and see if the ShipTo box has a number in it.
-Todd C.
Sent: Wednesday, December 16, 2015 11:39 AM
Subject: [Vantage] E10 Bartender Shipping Labels
I have a need to print the Customer Ship To address to a shipping label.  I have the label set up but when I use the following data fields that are output:
ShipHead_ShipToCust_Name
ShipHead_ShipToCust_Address1
ShipHead_ShipToCust_Address2
Etc.
The data that is being output is the Sold to customer name and address not the Ship to customer name and address.
Has anyone else seen this and if so, how did you address?
Thanks in advance,
Mike
Etc.
Thanks in advance,
Mike
-Todd C.
Etc.
Thanks in advance,
Mike
