E10.2 BAQ - Time Phase Inquiry
Hi all,
I came across this post and received my results instantly. It basically recreates a rudimentary timephase.
However, it doesn’t work well because when the RunningSum value = 0, then the RunningSum value on the next line is not accurate.
I’d be grateful if anyone would be able to provide a solution for this issue.
@hymal7
Check out this method. You should be able to make a running total ordered by date, partitioned by part number.
